cwm recovery for rk3188
    Guys, how to root my rk3188 (iMito QX1)? To use busybox need this change.
      CWM for Q7 (NOT WORKING)
      Hi guys,
      I purchased the Q7 model and been dying to get the Clockworkmod recovery.
      The current software is still stock and Unrooted.
      i downloaded the image file and followed the instruction to install through the finless rom tool. it goes through and says everything ok but the box then boot to the software just like nothing happened.
      when i go to recovery " Holding recovery button while powering" I still see the stock recovery.
      I can't use "su" commands nor use the reboot app because i don't have root.
      Is there anyway to get the CWM without having to go through the root?
      I really appreciate anyone that can help.
        hi leolas if i upload my tablets recovery can you make it cwm ?
        one request can you make a step by step guide for noods (us) how to compile cwm ? cos i try 2 weeks and i cant make it .
        thanks
          Hi leolas!
          You can make the recovery for the RKM MK802IV with new wifi chip?
          Here is the fw: http://www.sendspace.com/pro/dl/uowd75
            Re: cwm recovery for rk3188
            thanks
            I Didn't have success compiling cwm from source s, like I said in first post fun from androtab got it I only modded his recovery and added a kernel on it.
            leolas
            sent from my phone.
            My devices:
            Gearbest.com)
              Originally posted by leolas View Post
              Of course install it under your responsability, be sure that you know how to flash it, bla,bla, bla, etc..
              Links for the devices:
              TV STICKS/BOX
              Minix X7: http://www.freak-tab.de/leolas/cwm/x...covery.img.zip
              dear Leolas can you add support ntfs or exfat format sd card in cwm recovery? because now in only see the fat32 format cards
                Please leolas can you help me out with this?
                i just want to make backup/restore from recovery. i don't need root or anything. can that be done on stock? if so please tell me how
                Originally posted by tvguy View Post
                Hi guys,
                  Originally posted by RSDamasceno View Post
                  Hi leolas!
                  i made one for it yet, sorry it is not in the first page because I dont have time enought to maintain it updated sorry.
                  your link: http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
                  I will try it, I can add a custom kernel with ntfs and exfat support, but I need to test if it works, I dint try it before.
                  Yes you can do it using rk androidtool, Download http://www.freak-tab.de/leolas/flash...ecovery-Q7.zip, and from your windows pc unzip it and run RKAndroidTool.exe, it comes preconfigured to flash the cwm for your device.
                  Leolas
                  My devices:
                  Gearbest.com)
                    Leolas
                    Thanks man!
                    Just one question... This recovery works with 4.2.2 and 4.4.2 FW?
                      In 4.4.2 I cant say, for sure it will not backup metadata partition.
                      leolas
                      sent from my phone.
                      My devices:
                      Gearbest.com)
                        leolas
                        sent from my phone.
                        Ok.
                        If I send you the recovery of the custom rom (4.4.2) that I use you can build the cwm?
                          Ok new recoverys for some devices:
                          Q7: http://www.freak-tab.de/leolas/cwm/Q...covery.img.zip
                          Please if you miss some cwm you asked before tell me, sorry but some weeks I am busy and most of the time I am from my phone, and only some days I got enought time to play with cwm recoverys.
                          leolas
                          Thanks.
                          Confirmed working on my Q7.
                            RK3188_Box_V3.0
                            This is my first post, but I have been reading this forum for about a month and learned a lot. Now I am ready to take the next step.
                            My box is rooted and I have installed Titanum Backup pro and Onlineandroid backuppro. I have uploaded both the recovery image and recovery log in a rar file. I don't know what else you migt need. I used onlinenandroidbackupfor the backup. I have read through this entire thread but not found a compatible recovery (I think) If I missed it I apologize.
                            On the board inside the box is this:
                            RK3188_Box_V3.0
                            2014-01-02
                            If possible would you make me a CWM recovery for this rom. Thankyou.
                              CWM for CS968?
                              hello;
                              what basis of CWM ,I have to use for CS968 please?
                              I tried the generic recovery, but I can not do any backup or restore in recovery.
                              thank you for this work
                                cwm for rkm rk902
                                I'm trying to correct a flashing screen on my new rk902 box. It seems from my research and futile attempts
                                to use my linux laptop to flash the latest stock ROM, that making the clockworkmod work work may be my only hope.
                                I've been through the procedure described at the beginning of this thread and when I ran the recovery/reboot script, I either
                                got a denied permission or the mk902 shutdown without reboot. Is this what was supposed to happen?
                                I'd really like to make this thing work. Thanks for any input.
