Be much appreciated
cwm recovery for rk3188
Which CWM recovery works with
MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.1.0 ) ?
I tried to put x7-cwm-recovery mentioned above but it does not work.
XT-Q7-V10 1.6 rk3188 experience
mi experiencia positiva después de probar.
Partiendo de un Q7 con mb XT-Q7-V10 con 2gb ram 8 gb rom bt y root en Android 4.2.2 Rom stock con logo R-Box.
Flashear update 7.30 (no la 7.40 que por cierto no funciona nada y el logo es android-tv, por lo que debe ser para otro modelo de mb)
cuando lo tengas todo instalado y en todo caso después del primer inicio de tu nuevo r-box kitkat 4.4.2, realizar root con cualquiera de los métodos correspondientes a kitkat 4.4.2.
entonces al playstore e instalar Arctools, abrir y elegir descargar iFive X2 Android 4.4.2 CWM Recovery by ManuPC. Elegir Instalar apps.
Se reinicia y...
KK 4.4.2 con CWM recovery mediante teclado usb.
__________________________________________________ ___________________________________
my positive experience after testing .
From a Q7 with mb XT- Q7 -V10 with 2GB ram 8 gb rom bt and root on Android 4.2.2 ROM with logo R -Box .
Flash update 7.30 (not 7.40 which certainly nothing works and the logo is android- tv , so it must be for another model mb)
when you have everything installed and in any case after the first start of your new r -box kitkat 4.4.2 , perform root with any of the methods corresponding to kitkat 4.4.2 .
then the playstore and install ArcTools , open and choose to download iFive X2 Android 4.4.2 CWM Recovery by ManuPC . Choose Install apps.
Restarts and ...
KK 4.4.2 with CWM recovery using usb keyboard
r-box kk & cwm recovery full working order.
Originally posted by leolas View PostOk new recoverys for some devices:
Q7: http://www.freak-tab.de/leolas/cwm/Q...covery.img.zip
Please if you miss some cwm you asked before tell me, sorry but some weeks I am busy and most of the time I am from my phone, and only some days I got enought time to play with cwm recoverys.
leolas
unable to mount any thing nor format/backup.
i also tried Androtab's generic, but it doesnt even boot into CWM. (black screen)
any ideas?
cwm recovery for rk3188 on Qc802
Originally posted by leolas View PostOf course install it under your responsability, be sure that you know how to flash it, bla,bla, bla, etc..
Links for the devices:
TV STICKS/BOX
Imito qx1: http://www.freak-tab.de/leolas/cwm/q...covery.img.zip
CX919: http://www.freak-tab.de/leolas/cwm/cx919-cwm-recovery.img.zip
Minix X7: http://www.freak-tab.de/leolas/cwm/x...covery.img.zip
UG007b: http://www.freak-tab.de/leolas/cwm/u...covery.img.zip
MK812A: http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
T428: http://www.freak-tab.de/leolas/cwm/T...covery.img.zip
The T428 recovery reports that works in all roms except in the lewy port of his rom to T428.
K-R42: http://www.freak-tab.de/leolas/cwm/k...covery.img.zip
Doobol-U2: http://www.freak-tab.de/leolas/cwm/d...covery.img.zip
timingpower rk3188: http://www.freak-tab.de/leolas/cwm/t...covery.img.zip
TABLETS cwm:
Pipo S1pro:http://www.freak-tab.de/leolas/cwm/s...covery.img.zip
Pipo M6: http://www.freak-tab.de/leolas/cwm/P...covery.img.zip
Hola Leolas, soy nuevo en el foro , en primer lugar enhorabuena por tu trabajo y luego quería saber si me podrías ayudar con un problema que tengo y me está desesperando:
El caso es que compré un stick tv android Qc802 con chip Rk3188T y rom Android 4.2.2 instalada y kenrel 3.0.36+ y quiero actualizarlo pero antes deseo hacer un backup de forma sencilla de la rom que me viene de fabrica, estoy intentando instalar el CWM pero me es imposible, probé con el método de tu Thread: cwm recovery for rk3188 con el zip para UG007b y el generico pero cuando desde terminal emulator reinicio en recovery , no reinicia solo se apaga. Luego prove a instalar con ArcTools app siguiendo este hilo http://www.freaktab.com/showthread.p...8-3066-devices y consigo que se reinicie en recovery pero salen estos mensajes:
CWM-based Recovery modified by androtab.info v6.0.3.1
E: Can’t find misc
E: Can’t mount /cache/recovery/command
E: Can’t find misc
E: Can’t mount /cache/recovery/log
E: Can’t open /cache/recovery/log
E: Can’t mount /cache/recovery/last_log
E: Can’t open /cache/recovery/last_log
E: Can’t find misc
Intento hacer backup y nada, salen mas errores. Si me pudieses ayudar seria genial.
Muchas gracias, un saludo.
P.D.. No se si en el foro se puede escribir en castellano , si no es asi, disculpas, pero hubiese tenido muchas digicultades para explicarlo en inglés.
CWM CAN'T MOUNT ETC ERROR
Leolas please help! I have an 802 mkiv. Stock firmware 4.2.2 new WiFi. Rooted by kingo. Arc tool installed cwm generic. Cwm boots/reboots but gives this error messageDoesn't work for me..i've successfully install CWM, but i get these errors in cwm:E:Can't found misc
E:Can't mount cache/recovery/log
E:Can't open cache/recovery/log
E:Can't found misc
E:Can't mount cache/recovery/last_log
E:Can't open cache/recovery/last_log
E:Can't found misc
Any ideas? Do you have custom firmware that I can flash by cwm?
Thank you
Cwm recovery for 802 mkiv
Originally posted by RSDamasceno View PostHi leolas!
You can make the recovery for the RKM MK802IV with new wifi chip?
Here is the fw: http://www.sendspace.com/pro/dl/uowd75
Originally posted by thafath View PostSame thing here. I tried the generic for my mk802IV AP6210, flashed boots ok, but can't do backup. I appreciate if you can do something for this device (if it's possible of course). I can provide logs and can test. Thank you.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
There are currently 2426 users online. 3 members and 2423 guests.
