cwm recovery for rk3188
    Re: cwm recovery for rk3188
    Originally posted by Aircraft800 View Post
    Did you have time to look at the MK902? I have used CR11S-CS968 ROM successfully, so maybe CWM recovery for it may work.
    I am downloading the stock mk902 rom, tomorrow morning I expect to upload the recovery.
    Originally posted by miss View Post
    muchas gracias Leolas, un abrazo
    De nada
    leolas.
    My devices:
    Gearbest.com)
      cwm recovery for mk902:
      mk902: http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
      leolas
      My devices:
      Gearbest.com)
        leolas
        Sweet! Thanks!!!
        It works great!! The only problem I had was making a backup to the external_sd, but internal worked fine and I had plenty of room.
        ERROR: "/external_sd/clockworkmod/backup/2014-02-26-15.00.29"
          Originally posted by thafath View Post
          Same thing here. I tried the generic for my mk802IV AP6210, flashed boots ok, but can't do backup. I appreciate if you can do something for this device (if it's possible of course). I can provide logs and can test. Thank you.
          Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
          Hi Leolas, here is the link to rom.
          Thank you.
            Sweet! Thanks!!!
            Dear leolas can you fix backup to the external_sd issue?
              Sweet! Thanks!!!
              what filesystem has your external_sd? be sure that you use a fat32 formated external sdcard. Please not use ntfs or ext4, because it can work in some devices but will fail in other , and remember I have only some devices, anyone can buy all devices
              leolas.
              My devices:
              Gearbest.com)
                Thank you.
                It will be great if I can got the stock rom, but anyway I am trying to make a cwm image with the neomode recovery. I will post it in a few minutes.
                Ok here it is:
                mk809: http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
                leolas
                My devices:
                Gearbest.com)
                  Ok new recoverys for some devices:
                  cs918b: http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
                  Q7: http://www.freak-tab.de/leolas/cwm/Q...covery.img.zip
                  cr11s-cs968: http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
                  Please if you miss some cwm you asked before tell me, sorry but some weeks I am busy and most of the time I am from my phone, and only some days I got enought time to play with cwm recoverys.
                  leolas
                  hola Leolas, el Q7 lo flasee con RKDevelopTool_v1.37, y no funciono el tv arranca bien pero al ir a reiniciar con recovery no arranca en recovery, lo intente tambien metiendo en la rom original con imgRePackerRK_102, desempaquetando borrando el original , poniendo el tuyo y empaquetando de nuevo tampoco funciono, que estoy haciendo mal??
                  pdt, Q7-cwm-recovery.img lo renombro antes de hacer nada a recovery.img, tal como aparece en mi rom original.
                  Gracias , que tal llevas la rom de tu telefono?
                    leolas
                    Leolas, here is the link to stock rom
                    http://www.sendspace.com/pro/dl/z80zb4
                    Thank you
                      Ok here it is:
                      leolas
                      Thanks -it works great with neomode 2.0
                      CS918(old wifi)+Air Mouse ea-01
                      Out: TV LG HDMI (1 day a week AV out Samsung Tv)
                      CX919(wifi ap6210)+Mele F10
                      Out: TV LG HDMI
                        El cwm recovery tiene q instalarse posterior a la rom, es decir, rom instalada, después de q ha arrancado por primera vez tu rom, entoces instalas el recovery usando cualquiera de los métodos en el primer post.
                        The cwm recovery must be installed after the Rom is installed, after your Rom boots at least 1 time, then you can install cwm using any way described in first post.
                        Thank you
                        Did you tested the cwm file That I posted in the post?
                        leolas.
                        My devices:
                        Gearbest.com)
                          [Quote = leolas; 151698] El CWM Tiene recuperación q instalarse posterior a la rom, es Decir, instalada rom, despues de q ha Arrancado Por Primera Vez tu rom, entoces instalas el recuperación Log in using CUALQUIERA De Los Métodos en el mensaje de imprimación. El recuperación CWM debe instalarse después de instalar la ROM, después de que sus botas Rom al menos 1 vez, entonces usted puede instalar CWM usando cualquier manera descrita en el primer post. ¿Has probado el archivo CWM que he publicado en el post? leolas. [/ COTIZACIÓN]
                          asi lo hice la primera vez con la rom original instalada , despues solo flasee el recovery y no cambio nada aparecia el mismo de la rom original aunque
                          RKDevelopTool_v1.37 me diga que todo ok, despues como esto no funciono probe con su
                          cd /sdcard/Download unzip term-install.zip unzip theNameOfYourSpecificCwmRecovery.img.zipmv theNameOfYourSpecificCwmRecovery.img cwm-recovery.img sh cwm.sh
                          esto tampoco funciono, da error en el comando mv recovery.img cwm-recovery.img
                          intente cambiarle el nombre a update.img y con el recovery antiguo actualizar y tampoco fianalmente probe descompilar y compilar tampoco funciono.
                          alguna idea????
                            Thank you
                            it"s working perfectly, tested everything except restore. Thank you very much Leolas, great job.
                            Sent from my MK809III using Tapatalk 2
                              Ok here comes some more cwm, please if I forgot some of them please repeat me the stock rom and I will try make them too:
                              cs968 with 8188 chipset: http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
                              t-r42-V2: http://www.freak-tab.de/leolas/cwm/t...covery.img.zip
                              Abot the mk908 for finless 1.7a, it has a problem, his stock recovery have not a kernel inside, so I need to know what is exactly your mk908 model to make a cwm for it
                              leolas
                              Hi, I tried this with my cs068/ap6210 chip set, everything is working except for restore, I can backup etc..but when tried to restore, it just give me a droid and full status bar and nothing moving. Thanks.
                                I had the same thing, but I just waited it out, it took a long time, nothing moving or indicating it was working, then "restore finished successfully" and everything worked.
