cwm recovery for rk3188
UM2 CWM
[QUOTE=leolas;92391]Please upload your stock recovery.img and I will make one for you. If you dont know how get the recovery.img please post a link to your stock rom.
Waiting your feedback
Great work on this guys! This is my first time on the site but if this is the quality of work i can expect I will definitely be a regular visitor! I have a Ugoos UM2 stick which I understand uses the 3188. If I upload my recovery image would you still be willing to make me a CWM? That would be incredible. Thanks so much!
Re: cwm recovery for rk3188
Originally posted by hle5128 View Postcan you make cwm for ippli mars i8 ?
firmware is here
(password: geekbuying.com)
[QUOTE=Oface82;125759]Originally posted by leolas View PostPlease upload your stock recovery.img and I will make one for you. If you dont know how get the recovery.img please post a link to your stock rom.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Problems
I followed the method without a PC on my rooted UG007b. Everything seemd to work fine and I am now able to boot into CWM. However it doesn't seem to work properly; when it first boots it says at the bottom:
Can't find misc
Can't mount /cache/recovery/command
Can't find misc
Can't mount /cache/recovery/log
Can't open /cache/recovery/log
The very bottom of my screen is cut off because the TV I'm using has some sort of annoying problem correctly communicating its aspect ratio to any device whatsoever over HDMI, so I'm not sure if the following appears at boot or only after I try to backup to external sd, but after that I find:
Can't mount /cache/recovery/last_log
Can't open /cache/recovery/last_log
Can't find misc
And upon trying to backup I also get:
SDCard space free: 7576MB
Backing up boot image...
Error while backing up boot image!
, which I'm assuming is related to the inability to access apparently anything at all that should be in the cache. The backup process fails and results in an empty backup folder. I'm trying to figure out what's gone wrong, and I'll try the PC-based method later if nothing else works, but please let me know (since others on UG007b may get the same problem?) if you have any idea what may be the matter and how it might be fixed. Thanks!
Edit: Upon going into /cache/recovery in a terminal and listing all contents, I find that it contains only two apparently empty files: last_install and last_log.
Originally posted by rceccleston View PostHi Leolas,
Would you be willing to create a custom recovery for the T-R42 V2?
Thank you.
Originally posted by sapphous View PostI followed the method without a PC on my rooted UG007b. Everything seemd to work fine and I am now able to boot into CWM. However it doesn't seem to work properly; when it first boots it says at the bottom:
Can't find misc
Can't find misc
Can't find misc
Before the cwm was installed can you boot in your stock recovery? This problem only affect some devices with some roms, and I cant figure what is wrong
Originally posted by leolas View PostThere is a lot of people with this problem, and I dont know why it is, seems a bad misc.img? cache partiton is bad formatted? really I dont know.
leolas
need a cwm for t-r42 with 2.0 board.
Firmware link (B351V2.0_HDMI_20131203): http://pan.baidu.com/s/1f7pYV
Thank you for your work.
Michael
Originally posted by leolas View PostThis is not the recovery.img nor the full firm, please give me a link to your stock full firmware or recovery.
leolas
Sent from my M6 using Tapatalk 4
Originally posted by sapphous View PostYes, the stock recovery worked before. It seems very bizarre. How can I mount cwm-recovery.img in the terminal to have a look around inside it? Maybe it's an issue there? The "can't find misc" message seems the most important--and the weirdest thing is the "Can't mount /cache/recovery/last_log" bit, because this file definitely exists on the filesystem. So perhaps it's having trouble mounting the disk itself in the first place?
Michael
Originally posted by rceccleston View PostSorry, please find below a link to a full working ROM.
Originally posted by Bazmamfoo View PostCan anyone point me in the right direction for a remote control app that will allow control of cwm recovery? Or does it have to be a USB remote? My tsm01 is not compatible.
Sent from my GT-I9505 using Tapatalk
And yes all of them have his own usb adaptor.
Originally posted by lifeisfun View PostHi Leolas,
did you have a time to look at it ?
Thanksand I can't stand in front of pc. All this requests are in my thing to do list.
There are currently 4217 users online. 1 members and 4216 guests.
