cwm recovery for rk3188
    Originally posted by vrolok View Post
    Excellent, thank you!!
    Yep, of course - it has the RK3188. I have already tried installing the generic one from "fun_" but to no avail. I get a blank screen.
    link to the recovery:http://www.freak-tab.de/leolas/cwm/E...covery.img.zip
    Remember that I havent your tablet so I cant test it properly, Be sure that you know how restore it to the inital working state, there must not be problems, but I want to advice it
    Originally posted by gollygosh View Post
    then you may find this page usefull
    also I could really do with a CWM for both the CX-921
    And I also have the Cosy Swan S400 with the AP2610 WIFI chip (it is a 2gig 8gb rom RK3188 TV stick)
    but I don't have the original ROM image and I could not find a link on the web for it either, if anyone has either then please post a link - as although I have CWM working on the device - I think it is not fully working as I often get SD card mounting issues and it seems to forget the Nand Flash partition on occasion which I am still trying to figure out. I have the Neomode 1.7 hybrid rom working on it, but it does seem to crash and then I have to do a complete wipe and re-flash from my home windows based PC via the usual finless /neomode tools. It might just be that my stick has some issues though,
    Anyway thanks to everyone at Freaktab -your hard work makes my life easier
    Thanks, I prefer that people give me the link to the firmware that it is working in their devices, there are so many clones around and some of them are different enought to make the recovery not work properly But thanks anyway. Your device seems so similar to mk802IV with ap6210. His cwm recovery and roms must work in your device, but I cant asure it..
    I am doing the one for cx921, I will post it soon.
    EDIT: here it is, I hope it works for you:http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
    leolas
    My devices:
    Gearbest.com)
      leolas
      You the man! Thank you so much. I will test it this eve and report back to you.
      cheers
        Hi Leolas
        THANK YOU - GOD THAT WAS FAST YOU IS MY NEW HERO. I will post back a report ASAP if it works OK etc.
        I have one more favor to ask, it is not really for this thread, but I am hoping you don't mind.
        I would love a parameter file for the CX-921 that splits the memory in halve basically divides the memory into 8*8gb as every parameter file I tried from other ROMS would not work with it.
        Hint hint - nod and wink to someone who can help
        I think I only need to adjust the last 2 lines but I don't know how - this is the original file with internal storage set at 2gb and nand having the rest of the 16 gb.
        FIRMWARE_VER:4.1.1
        MACHINE_MODEL:rk30sdk
        MACHINE_ID:007
        MANUFACTURER:RK30SDK
        MAGIC: 0x5041524B
        ATAG: 0x60000800
        MACHINE: 3066
        CHECK_MASK: 0x80
        KERNEL_IMG: 0x60408000
        #RECOVER_KEY: 1,1,0,20,0
        CMDLINE:console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000
        mtdparts=rk29xxnand:0x00002000@0x00002000
        (misc),0x00008000@0x00004000
        (kernel),0x00008000@0x0000C000
        (boot),0x00008000@0x00014000
        (recovery),0x000C0000@0x0001C000
        (backup),0x00040000@0x000DC000
        (cache),0x00400000@0x0011C000
        (userdata),0x00002000@0x0051C000
        (kpanic),0x00100000@0x0051E000(system),-@0x0063E000(user)
        Above is a copy of the Parameter file from a custom ROM made by Lewie and Walter77 - http://www.xbmcandroidtv.com/forum/e...-walter77.html
        Sorry - but this is just one of those problems that is really bugging me and hey Leolas you look like you have the expertise to sort this in no time. PM me if you want - sorry to hijack this thread a little on this.
        Thanks once again.
          I am new here and many things are not clear for me.
          I received my k-r32 yesterday and now I would like to install firmware Lewy or wasser but before I do that it would be good to save current firmware. How can I do this? If something goes wrong I would like to have way to recover previous version.
          Is anywhere manual (step by step) how to dump factory firmware and install newone ?
          I am not sure that soft from Lewy is compatible with my device because it is probably with new version of board and as I read it is problem with ethernet after instalation.
            Installed and fully functional on my Edison 2 QC
            Gracias!
            **EDIT:
            I actually get into troubles when I try to backup my data.
            From the main menu, I go into "back and restore".
            If I then choose "backup to external card", I get no prob whatsoever.
            But... by simply choosing the first option: "backup", I obtain:
            "Can't mount backup path" !!!!
            In the log, I then find the reason, viz:
            "failed to mount /dev/block/mtd/by-name/user (no such file or directory)"
            Any idea??
            Cheers
              Re: cwm recovery for rk3188
              FIRMWARE_VER:4.1.1
              MACHINE_ID:007
              MAGIC: 0x5041524B
              ATAG: 0x60000800
              MACHINE: 3066
              CHECK_MASK: 0x80
              Thanks once again.
              I will take a look on it, probably today.
              Originally posted by GreatZ View Post
              K-R42 I suppose you want to say. You can use some dump ways, with flash_image bin, or using dd, I am from mobile now, I will sent you a link.
              Gracias!
              **EDIT:
              Any idea??
              Cheers
              Oooops I need to take a look on it, maybe I miss something.
              leolas.
              My devices:
              Gearbest.com)
                leolas.
                yes - K-r42. What dump ways? what is dd ? Please send a link, I will be grateful.
                This is what I understand it:
                First I connect my box to PC and:
                0) Open ROM Flash Tool.exe
                1) Enter the flash mode
                2) Extract the recovery.img from specific cwm image, rename it to recovery-cwm.img and place it in the folder FinlessROM (this step is only to facilitate the next step)
                3) Let marked only the "recovery" and set the path FinlessROM\recovery-cwm.img (see image)
                4) And last click Flash ROM
                For step 2 I choose file from your second post in this topic:
                K-R42: hhttp://www.freak-tab.de/leolas/cwm/kr42-v2-cwm-recovery.img.zip
                Then I wait until complite and.... ?
                use Reboot App ??
                what is next step to dump/save my stock firmware?
                  Way cool - if you can sort out my parameter problem then I am your slave for life
                  Thanks for taking the time out to do all this.
                    Master leolas.
                    If I use an app to transfer apps to the sdcard, when the CWM backing up the apps moved to the sdcard, will be considered?
                    ...tks...
                    Enviado de meu CS968 usando Tapatalk
                      cs968-cwm-recovery.img.zip
                      There is certain devices (only a few) that don't work with the cwm, I didn't got any of them yet, with all my wireless or standard keyboards it works. Try tp use other usb keyboard.
                      Of course any bt keyboards Will work.
                      i guess it means that navigation from ir-remote does not work at cs968-cwm-recovery.img.zip. i tried two recovery images with my cs968: generic and yours. in generic recovery ir-remote work success, but in yours is not, only USB mouse/keyboard. can you fix it please?
                      the default scale of recovery screen is too big amd does not fit to the screen - i don't see lot of text at screen corners. can you make the default scale of recovery for example 50 instead of 100?
                      there is errors in recovery.log:
                      Code:
                      I:Checking for extendedcommand...I:Skipping execution of extendedcommand, file not found...
                      I:Set boot command ""
                      W:failed to mount /dev/block/mmcblk0p1 (No such file or directory)
                      SD Card space free: 30420MB
                      Backing up boot image...
                      mtd: read error at 0x01000000 (No such file or directory)
                      Backup of boot image completed.
                      Backing up recovery image...
                      mtd: read error at 0x01800000 (No space left on device)
                      Backup of recovery image completed.
                      Backing up kernel image...
                      mtd: read error at 0x01000000 (No space left on device)
                      Backup of kernel image completed.
                      Backing up system..
                      but created images looks like correct. what means these errors? full log in attachment.
                      thanks.
                        CWM for Aoson M33
                        Hello,
                        I ahve been looking for a CWM for my Aoson m33, but i have failed inthis journey. Is possible that you could tellme how Can i get one CWM for my tablet.
                        Just in case I have the img file stock rom, if you need to do the cwm
                        Thank in advance
                        Best Regards
                        Orlando
                          CX-921 -CWM - Feedback
                          It worked - did a backup and restore - with no problems found - Sorry it took a while, this is first chance I had to test it.
                          Thanks Mr L
                          Now I just need a parameter file that works with this bloody CX-921 box - it works fine with the 4gig parameter file from Finless Bobs 1.7 Neo X7 rom, but when I try any of the other higher parameter files the box just hangs at the boot screen, I really want 8*8 - HELP.
                          Also I think I found the Cosy Swan S400 rom - so as to allow you to make a CWM from it:-
                          It was posted on Freaktab here -
                          Oh and one last favor - if you do un-compact the above image, then can you upload it as an image that is broken into it's component parts - you know - kernel / parameter / etc/ .
                          As soon as I get some currency - you my friend - have made the list
                            Sorry, but in the last days I am a little missed, so busy. In the moment I got some free time I will try to make the new petitions.
                            Please orlapa, if you have a link to the Aoson stock rom please give it to me.
                            leolas
                            My devices:
                            Gearbest.com)
                              Hey no preasure
                              miss-typed see next post
                                Hey no pressure
                                I am already in debt to you - and as soon as I am out of financial debt myself, then like I said you sir - have made the list
