cwm recovery for rk3188
    Originally posted by leolas View Post
    Sorry a lot, but no, I am in my father town with some family, and I only return to my city some days for a few hours and I can't stand in front of pc. All this requests are in my thing to do list.
    leolas.
    Didn't mean to pressure you
      CWM for MK 908 Finless ROM 1.7a
      Hi leolas,
      could you please make a CWM for MK 908 Finless ROM 1.7a?
      You will find the whole ROM here:
      Thank you and best regards
        Enter recovery when you can't boot into android
        Sorry if I missed it, but is there a way to enter recovery even if you can't boot., by holding in the reset button or something?
        I made some system changes and now I'm in a boot loop so I can't "reboot" into recovery. I need to boot directly into it.
          The exact way to boot to recovery is device specific. What device do you have, hopefully if you let us know someone will have an answer for you.
          900Supersport
          freaktab developer
            MK908 v3
              Basically is a boot.img with a kernel inside 900supersort have a great thread with his kitchen link about how unpack and work with it. I am from mobile so I cant give you the link.
              (Edit)
              Thanks so much! I messed around with recovery.fstab and got nearly everything working. Then I ended up restoring the stock firmware to get a look at the original recovery.fstab--and it turns out the stock firmware from Ugoos is not the stock firmware that shipped with my device... I now have horrible wifi problems--but your CWM image now works too
                Originally posted by wusel678 View Post
                Hi leolas,
                www.freak-tab.de/finless/tronsmart_mk908_finless17a.zip
                Happy new year...
                Any news about CWM for MK 908 Finless ROM 1.7a? (PCB is V5)
                  Re: cwm recovery for rk3188
                  Tomorrow I will come back home, I hope to have aome time to make some of them.
                  leolas.
                  My devices:
                  Gearbest.com)
                    Happy New Year to all of you folks!
                    Leolas, I know that you just returned but I have one more request.
                    Just received atv580 box, and I like to try to install cwm on it. I have no links for the installed rom (Android 4.2.2 kernel 3.0.36+) is there any existing version I can try? Would need to use SD card method since there is no otg port and it did not come rooted unlike the atv520.
                      You could try seeing if the generic CWM for RK3188 devices boots on your device.
                      However, without the original ROM to hand, you risk your device not booting until a ROM becomes available.
                      In this case, I would highly recommend investigating backing up your current ROM prior to modifying your device.
                      Sent from my Nexus 4 using Tapatalk
                        Good point, but how do I backup the installed rom?
                        This is why I wanted to install cwm
                        Tried the generic update.zip but got message that it is invalid package
                          Other than Linux RKtoolbox, I'm not familiar with a Windows tool.
                            Try this from Google Play Store:
                            Online Nandroid Backup * root - Backup without recovery modus (CWM)
                            Take a look at xda-developers for more infos:
                            Nandroid backups are usually performed in recovery mode. This means you would have to turn off your phone and reboot in recovery mode, which wastes a whole lot of time rebooting and a lot more time offline. For me, this has been a killer as I do...
                              http://forum.xda-developers.com/show....php?t=1620255
                              Thanks, but this will only work on rooted device
                                Lets say one day I need to return my device for manufacture warranty.
                                If CWM is flashed on my device, if I use RockChip Batch Tool to flash original manufacture file "update.img" will that overwrite CWM and restore back to factory state?
                                Device I'm referring to is TimingPower RK3188 if it makes a difference I also have a Minix Neo X7 don't remember what Minix provides as file to do write firmware.
