I am not sure, I never use it in rockchip, because you can to select a parameter file with the /data amount that you want. In other devices I had I repartitioned the sdcard (external) to add a partition to install apps on it, but in those devices I cant repartition internal memory, so thats is why I use it, in rockchip is very easy select a parameter
About some remote controllers cant be used, sorry, but I have no idea of how make them work, all my generic (and cheap) remote controlers work
I am downloading the S400+AP6210 rom to make a cwm for it and upload the rom parts
cwm for S400 AP6210:http://www.freak-tab.de/leolas/cwm/s...covery.img.zip
S400 rom unpacked:http://www.freak-tab.de/leolas/cwm/sources.zip
leolas.
