cwm recovery for rk3188
LOL
Originally posted by leolas View PostThe user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
Re: cwm recovery for rk3188
Originally posted by tico View PostI have a T-R42 (my first android device)and would like to know if a cwm recovery is available for it and also I would like to get the stock firmware for it too if it is available some ware too.Thank you very much for your great work.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostTry to Flash the cwm recovery.img and misc.img too, there is some problems in some lewy roms.
leolas.
2. Wasser recovery.img - with kernel. To flash through ROM Flash Tool - put a check mark to flash the kernel, or only for recovery?
3. If the check box to deliver, then the system does not boot after flashing.
I too, sometimes, you do not quite understand, Google Translator is not conducive to free communication.
Originally posted by thistle View Post1.You wrote, that I need to flash recovery. img and misk.img. To flash misk.img - must be the presence of a file. I asked where I can download it.
2.only recovery.img, using mine or waser recovery. Kernel is not needed to reflash because the recovery.img has his own kernel inside.
3. My English is not very good, sorry a lot but I can't understand this part. What is "if the check the box to deliver"? The second part about Google translator, yes, sometimes Google translator makes a very hard to understand translations
Originally posted by leolas View Post1.Can you give me a link to your stock rom? I will extract the stock misc.img for you.
3. ......., sorry a lot but I can't understand this part.
leolas.
Unfortunately, Stock ROM, I've tried to flash: http://www.mediafire.com/download/4x...U_20130619.rar
and http://d-h.st/RLA - both have in Recovery - android with a red triangle.
I'll try to ask for a link to the Stock firmware at the seller, suddenly get.
T-R42 CWM recovery
Originally posted by leolas View PostIf I can got your stock recovery.img, I can do it, tomorrow I will explain a easy way to obtain a backup of recovery.img. The only prerequisite is to be root.
leolas.
Originally posted by tico View PostThanks leolas,that would be great.I rooted my device already and tried to backup my stock rom with no success.
I hope this one can help a lot of people, follow the instructions carefully and if you have any question please ask there, if I can help I will do itWith this guide you can make a backup of your stock rom and flash roms too from the stick without pc
I made a new k-r42 cwm recovery, I used for this one the stock rom from kr42 from july. If someone with this device can test it please report back if it works
link:http://www.freak-tab.de/leolas/cwm/k...covery.img.zip
If someone have problems rebooting with k-r42 to recovery please flash this misc.img:http://www.freak-tab.de/leolas/cwm/misc.img.zipREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI made a new k-r42 cwm recovery, I used for this one the stock rom from kr42 from july. If someone with this device can test it please report back if it works
If I flash misc.img without recovery.img, when you first boot into Recovery for a short time android normal, with blue crystal (during scanning at startup recovery), then the crystal is replaced by a red triangle.
This is seen and on Stock Firmware and on Lewy20041 v.1.2.0 720P. A little something else to change into misc.img.
After applying misc.img on firmware Lewy20041 lost Root.
Originally posted by thistle View PostChecked the recovery.img and misc.img. My TV Box not boot after applying recovery.img, to flash additionally misc.img does not help.
Install the stock rom, root it, try terminal emulator&busybox way to install cwm recovery. Lets see if in this way it works. Is the only solution I can think.
Originally posted by leolas View PostSorry then, I don't have this device, but only 1 more try if you want.
leolas.
My device: http://www.aliexpress.com/item/CS918...023696089.html was taken here.
Only the inscription Smart TV Box on the bottom of the machine and, on the face of the written ANDROID.
Seller still silent, not responding to my request for a link to the Stock ROM for this Device.
Originally posted by thistle View PostAll the Stock ROM - a red triangle in Recovery. Still try?
After flash cwm recovery then it must work, it didn't work for you, I dont know why
Maybe a different device????REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostInstall the stock rom, root it, try terminal emulator&busybox way to install cwm recovery. Lets see if in this way it works. Is the only solution I can think.
leolas.
Stock ROM - http://d-h.st/RLA, Root made,....etc.
BusyBox
Terminal Emulator:
no Errors,
entering sh cwm.sh
error opening cwm-recovery.img failed with error: -1
Did you all the steps? Renaming too?
1. Install from play store the free apps Terminal emulator (https://play.google.com/store/apps/details?id=jackpal.androidterm&hl=es)and busybox installer(https://play.google.com/store/apps/d....busybox&hl=es)
2. Open busybox installer, grant superuser permission,Use normal install (Not smart Install) then when it finish close the app.
3. Download http://www.freak-tab.de/leolas/cwm/term-install.zipfrom your stick, it must be downloaded in /sdcard/download/ (this is the default folder if you use the stock browser for download it.
4. Download your specific cwm zip from this thread and it need to be in /sdcard/download too.
5. Open Terminal emulator and write:
Code:su cd /sdcard/Download unzip term-install.zip unzip theNameOfYourSpecificCwmRecovery.img.zip mv theNameOfYourSpecificCwmRecovery.img cwm-recovery.img sh cwm.sh
After write su you must grant superuser permission to terminal emulator.
There are currently 1496 users online. 2 members and 1494 guests.
