cwm recovery for rk3188
Originally posted by tdriver View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostSorry but I dont know why this rom cant reboot to recovery, I pmed lewy and he is informed
before i don't knowDevice:Tronsmart MK908 v1,Cozyswan S400
Rom: Finless Bob v1.6,Stock Rom
Kernel:Finless Bob v1.6
CWM-Recovery:by Leolas
Re: cwm recovery for rk3188
Originally posted by Torkemada View Poston Mk908 v121 from lewy can boot to recovery after i flash that file (cwm)!
before i don't know
@ leolas
Cwm-recovery for device MK812A does not work on DOOBOL_U2
(it is not the same device, does not have BT, also some other hardware changes).
Please make cwm-recovery for device DOOBOL_U2 .
DOOBOL_U2_stock_recovery.img : http://ul.to/72gsasvt
Thanks for your help.
Originally posted by zzmakii View PostSuccess ! MK812A cwm-recovery is working.
I have tested twice backup and restore from internal NAND memory, and it is working OK.
But when trying to backup to external SD (16GB microSD), there are errors :
Can't mount backup path
W:failed to mount /dev/block/mmcblk0p1 (Ivalid argument)
W:failed to mount /dev/block/mmcblk0 (Invalid argument)
Cant mount backup path
I:Set boot command ""
I:Cant format unknown volume: /emmc
Is it parhaps because external SD is formatted in NTFS ? Any hint ?Originally posted by zzmakii View Post@ leolas
Is a new link to the stock recovery? I am out of home for weekend. So untill Monday I can't make more cwm. Monday I will try again.
Originally posted by leolas View PostThen works or not? I think I misunderstand something this cwm cant work with ntfs sdcards.
leolas
Cwm-recovery you provided me for MK812A does work OK on MK812A, I have tried it few times, but only on NAND storage, it does not work on external SD formatted in NTFS. Sorry, at the moment I have no possibility to reformat external SD in FAT32 with previously saved content (my wife will kill me if I screw her games).
But this cwm-recovery for MK812A does not work on DOOBOL_U2 (probably because of different hardware). So please if you can make cwm-recovery for device DOOBOL_U2, therefore I provided link to stock recovery.img. I can wait few days, no problem. Thanks in advance.
Originally posted by zzmakii View PostI have two devices, MK812A and DOOBOL_U2. They are very similar, but NOT the same, the second does not have BT, and has different WiFi chip.
Do you think you can make one for the k-R42? Here is a stock rom with root
Originally posted by leolas View PostPlease upload your stock recovery.img and I will make one for you. If you dont know how get the recovery.img please post a link to your stock rom.
Waiting your feedback
T428: http://www.freak-tab.de/leolas/cwm/T...covery.img.zip Reported to work except in lewy hibrid rom for T428.
mk908 I: http://www.freak-tab.de/leolas/cwm/9...covery.img.zip Fail, not tested yet.
The T428 recovery reports that works in all roms except in the lewy port of his rom to T428.
Originally posted by killer5000 View PostDo you think you can make one for the k-R42? Here is a stock rom with root
https://www.dropbox.com/s/oe5k5r1a1p..._lewy20041.rar
Originally posted by kolmanb View PostI have instaled rom ( X7_BOX 20130822_1080fb.rar ) with root access instaled X7 cwm-recovery
and everything works great.
Thanks for your help.Originally posted by killer5000 View PostDo you think you can make one for the k-R42? Here is a stock rom with root
Want to flash any rom or kernel using cwm? read here:http://www.freaktab.com/showthread.php?6928-Some-cwm-installable-zips&p=94448#post94448Last edited by leolas; 09 September 2013, 20:52.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
mission completed
i couldnt flash the recovery from the pc on mk802iv and i flashed it through terminal.
thx leolasFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Originally posted by leolas View PostYes, it seems to be only in lewy rom for T428.
Originally posted by neoal View Posti couldnt flash the recovery from the pc on mk802iv and i flashed it through terminal.
thx leolas
Originally posted by Molle View PostAnd particularly the 'RKAndroidTool' flashing method. I just tried terminal-based flashing and it worked like a charm.
There are currently 1875 users online. 1 members and 1874 guests.
