leolas
cwm recovery for rk3188
Re: cwm recovery for rk3188
Originally posted by Molle View Post
MK812A cwm-recovery
Originally posted by leolas View PostThis is the more strange stock recovery that I ever seen in rk3188 devices, it has a lot of bt and wifi stuff on itand usually they don't have it in the recovery, anyway I made it please test it if you can.
http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
If I install cwm-recovery on working device, and try to reboot to recovery with Petrus apk, it will not boot any more (stuck on opening logo).
If I flash full new image, but only with cwm-recovery instead of stock recovery, on power device boot into cwm-recovery, but with errors :
E: Invalid command argument
E: Can't mount /cache/recovery.log
E: Can't open /cache/recovery.log
E: Can't mount /cache/recovery/last.log
E: Can't open /cache/recovery/last.log
And if I try "Reboot now", device will not boot any more (again stuck on opening logo).
Any suggestions ?
Any suggestions ?
Originally posted by leolas View PostAnd if you can try the recovery that comes with lewy rom too. Maybe the problem is there.
I don't think there are any problems with the flashing itself as I have now reflashed the recovery partition several times back and forth. Since I have also tested with two totally unrelated kernels, I can only assume that there is something odd in the 'misc' partition image of the HFW ROM v1.2.1.
Can I flash the 'misc.img' from a different ROM or will that cause corruption?
EDIT: Actually I can't tell the state of the device after trying to reboot to recovery. After I execute the reboot, all USB devices (connected to a USB hub) turn off. The power light stays on in the device but my TV receives no signal.Last edited by Molle; 04 September 2013, 09:59.
MK812A cwm-recovery
Success ! MK812A cwm-recovery is working.
I have tested twice backup and restore from internal NAND memory, and it is working OK.
But when trying to backup to external SD (16GB microSD), there are errors :
Can't mount backup path
W:failed to mount /dev/block/mmcblk0p1 (Ivalid argument)
W:failed to mount /dev/block/mmcblk0 (Invalid argument)
Cant mount backup path
I:Set boot command ""
I:Cant format unknown volume: /emmc
Is it parhaps because external SD is formatted in NTFS ? Any hint ?
Originally posted by leolas View PostGood then it is cause something goes wrong in the flash procces with the other T428 user, please test the second way and install it using terminal emulator please. When 2 people confirm me that it work I will submit it to the working post. Thanks a lot for test it
ROM: Finless Bob 1.6 ALPHA TEST with strauzo kernel
With Flash tool only checking T428-cwm-recovery.img - OK
With teminal without PC - OK
Originally posted by Molle View PostLewy's ROM comes as a batch image and I don't have time to start dissecting it. But I did try with the stock recovery image from the nexus rom and the results were the same.
Originally posted by opengl1971 View PostAny news about the ug007b cwm recovery ?
Originally posted by tdriver View Posttried again, same here, after "reboot to recovery" The power light stays on in the device but my TV receives no signal.
Originally posted by leolas View PostSorry can you give me a link to the stock recovery or Rom?
leolas
Originally posted by opengl1971 View PostIt was already posted here by fabienk as he corrected the broken link , here it is:
http://bk9vz3.1fichier.com/en/
Originally posted by opengl1971 View PostAny news about the ug007b cwm recovery ?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 1967 users online. 2 members and 1965 guests.
