cwm recovery for rk3188
Fun has a cwm for the u30gt2. The generic works OK too but I like to have a kernel embedded in recovery.900Supersport
freaktab developer
Originally posted by Torkemada View Postgreat !
waiting for Mk908 file
here i put the files:
http://www.freaktab.com/showthread.p...ll=1#post90266REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by 900supersport View PostFun has a cwm for the u30gt2. The generic works OK too but I like to have a kernel embedded in recovery.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostNo so time usually for me is taking only 2 or 3 minutes.
What filesystem is in your external sd?
And it is full? Have enough free space?
Can you adb connect the device?
leolasLive as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by leolas View PostSorry, I am having problems with your recovery the kernel inside this recovery dosent boot in my qx1, I have to disconect today but I will follow on it yesterday. I will try with other recovery for 908. What is your 908 version?Device:Tronsmart MK908 v1,Cozyswan S400
Rom: Finless Bob v1.6,Stock Rom
Kernel:Finless Bob v1.6
CWM-Recovery:by Leolas
Re: cwm recovery for rk3188
Originally posted by jellywobbles View PostI will try - what is the command that I type in Terminal mode?
adb cat /tmp/recovery.log
while it is running the md5 check.
Try to make a backup to internal sd too please and tell me if the problem persist.
Originally posted by Torkemada View Postfirst version
leolas
Will reformat ext sd card & try again. Thanks for your help.Live as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by jellywobbles View PostBackup to internal sd took 7 minutes.
Will reformat ext sd card & try again. Thanks for your help.we are here for help between us.
Test it again to external formated in fat32, ntfs don't works good in recovery.
Originally posted by opengl1971 View PostHi leolas , can you please do a cwm recovery for the ug007b (old chipset) ?
Originally posted by leolas View PostOf course, please can you give me a link to your stock recovery?
I qill try to finish the 908 recovery and the next one is yours.
Waiting for feedback about T428.
I have installed cwm successfully (one included in Hoabycsr roms) on my MK908 v3.
Is there a way of starting the stick in cwm recovery directly using only hw, like pin+power for starting in bootloader.... I had a boot loop and would have liked to have gone straight to restore the backup from the ext. sd card, but couldn't get into recovery.
Ok, I will download some stocks and try, when you reboot to this recovery in your Rom, does it work?
leolas
Code:u0_a48@android:/ $ adb cat/tmp/recovery.logAndroid Debug Bridge version 1.0.31 -d - directs command to the only connected USB device returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is running. -s <specificdevice> - directscommand to the device or emulator with the given serial number or qualifier. Overrides ANDROID_SERIAL environment variable. -p <product name or path> - simple product namelike 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices[-l] - list all connected devices ('-l' will also list device qualifiers) connect <host>[:<port>] -connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IPdevice. Port 5555 is used by default if no port number is specified. Using this command with no additional arguments will disconnect from all connected TCP/IP devices. device commands: adb push <local> <remote> - copy file/dirto device adb pull <remote> [<local>] - copy file/dir fromdevice adb sync [ <directory> ] - copyhost->device only if changed (-l means list but don't copy) (see 'adb help all') adbshell - run remote shell interactively adb shell<command> - runremote shell command adb emu<command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adbjdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] [--algo <algorithm name> --key<hex-encoded key> --iv <hex-encoded iv>] <file> - push this package file to the device and install it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data) ('-s' means install on SD card instead of internal storage) ('--algo', '--key', and '--iv' mean the file is encrypted already) adb uninstall [-k] <package> - remove this app package from thedevice ('-k' means keep the data and cache directories) adbbugreport - return all information from the device that should be included in a bug report. adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all][-system|-nosystem] [<packages...>] - write an archive of the device's data to <file>. If no -f option is supplied then the data is written to "backup.ab" in the current directory. (-apk|-noapk enable/disable backup of the .apks themselves in the archive; the default is noapk.) (-shared|-noshared enable/disable backup of the device's shared storage / SD card contents; the default is noshared.) (-all means to back up all installed applications) (-system|-nosystem toggles whether -all automatically includes system applications; the default is to include system apps) (<packages...> is the list of applications to be backed up. If the -all or -shared flags are passed, then the package list is optional. Applications explicitly given on the command line will be included even if -nosystem would ordinarily cause them to be omitted.) adb restore <file> - restore device contents from the <file> backup archive adbhelp - show this help message adbversion - show version num scripting: adbwait-for-device - blockuntil device is online adbstart-server - ensure that there is a server running adbkill-server - kill the server if it is running adbget-state - prints: offline | bootloader | device adbget-serialno - prints: <serial-number> adbget-devpath - prints: <device-path> adbstatus-window - continuously print device status for a specified device adbremount - remounts the /system partition on the device read-write adb reboot [bootloader|recovery] - reboots the device, optionally intothe bootloader or recovery program adb reboot-bootloader -reboots the device into the bootloader adbroot - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip<port> - restarts the adbd daemon listening on TCP on the specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /datapartitions will be updated. - If it is "system" or "data", only thecorresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync, sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes priority over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these debug tags are printed. 1|u0_a48@android:/ $
There are currently 2207 users online. 1 members and 2206 guests.
