cwm recovery for rk3188
    Originally posted by leolas View Post
    I suggest the second way, using terminal emulator, but wait, I will try today to locate your stock rom, waser told me that there was something wrong in my kr42 cwm. I will try to rebuilt it, it seems the same device than your.
    leolas.
    OK, I will wait.
      mk908v2
      How do you go to recovery mode?
      From terminal try to use
      su
      reboot recovery
      leolas.
      Yes, I tried from terminal. It did not go to recovery. It just rebooted.
      I tried with the the reboot app that is included in Finless rom. Same result.
      I tried with Rom Manager app. Same result.
      I flashed back the recovery img from Finless rom and then I could get to recovery.
      But no CWM.
      Doug.
        Re: cwm recovery for rk3188
        But no CWM.
        Doug.
        Plese, can you try flashing stock misc.img and cwm recovery.img using finless flash tool?, test if you can boot to recovery in this way.
        When you try to flash the recovery using terminal emulator, where it fails? Can you describe where is the problem step by step?
        leolas.
        My devices:
        Gearbest.com)
          leolas.
          Heeya, again, can i have a minute of yours? got one question that i cant seem to answer XD
          ill send ya a pm since it is out topic...
          The user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
            Please can you give me a link to your stock recovery.img or stock rom?
            leolas.
            Apparently, in my device stood recovery.img is the same as on this TV Box: http://blog.geekbuying.com/index.php.../#.UleqcBDKK9I.
            The description and screenshots is the same as mine, but I had a firmware of 20130827.
            Download Link: http://www.mediafire.com/download/4x...U_20130619.rar
              Ok I will work in this stock image.
              leolas.
              My devices:
              Gearbest.com)
                ... from Windows I dont know ...
                I also do not think that this is possible (errorsoft )...
                Thank you for your offer, but at this moment I've another problem, that needs to be fixed once before other experiments...
                I will then come back to it...
                Greetings
                RK3288 Devices
                - Overview BOX (LINK !)
                  cwm recovery for k-r42
                  i created new cwm recovery for k-r42, it works fine for me on k-r42 box. You can download it from the
                  big thank to leolas for his info how to repack cwm!
                    leolas.
                    I tried flashing stock misc.img and cwm recovery.img using finless flash tool and now I can boot to recovery. Thank you for your help. I was able to backup and restore.
                    I also tried again to flash the recovery using terminal emulator and no errors this time. Before I had an error unzipping both files.
                    Why do you think I had to flash misc.img?
                    Doug
                      Doug
                      Good!!
                      Fail unzipping is because something in busybox installation wad bad.
                      misc.img is the part of the device who manage boot: normal, recovery or bootloader. Sometimes use the misc.img for other sticks works, but sometimes it not work, so when we port other stick Rom, we must use our stick stock misc.img
                      leolas.
                      My devices:
                      Gearbest.com)
                        Through Terminal Emulator: error opening cwm-recovery.img failed with error: -1
                        Again the same thing.
                        Re-install the firmware Lewy 1.2.0 720P, android in recovery with a red triangle. So all the problems of the firmware, not the image files cwm - recovery. Can try to install cwm - recovery through ROM FlashTool?
                        Tried to install recovery.img (wasser and my post) via ROM Flash Tool. There is no entrance to the recovery by the standard method (button input, HDMI, power). Partition recovery is not opened.
                        The system is loaded and, in principle, the device works.
                          Try to Flash the cwm recovery.img and misc.img too, there is some problems in some lewy roms.
                          leolas.
                          My devices:
                          Gearbest.com)
                            leolas.
                            Where can I find misk.img? And when flash recovery.img from wasser, to put a tick kernel? When I put - the system does not boot.
                              Sorry, but I don't understand well what you said. Can you try to explain it clear?
                              leolas.
                              My devices:
                              Gearbest.com)
                                T-R42 CWM recovery
                                I have a T-R42 (my first android device)and would like to know if a cwm recovery is available for it and also I would like to get the stock firmware for it too if it is available some ware too.Thank you very much for your great work.
