u0_a54@android:/ $ su - root@android:/ # cd /mnt/sdcard/Download root@android:/mnt/sdcard/Download # ls AmazonApps-release.apk T428-cwm-recovery.img.zip cwm-recovery.img cwm.sh term-install.zip root@android:/mnt/sdcard/Download # sh cwm.sh cp: flash_image: No such file or directory root@android:/mnt/sdcard/Download #
cwm recovery for rk3188
I have made a mistake trying to install CWM on T428
Code:T428
Originally posted by webipsum View PostMaster leolas.
If I use an app to transfer apps to the sdcard, when the CWM backing up the apps moved to the sdcard, will be considered?
...tks...
Enviado de meu CS968 usando Tapatalk
Please, someone could guide me about the question above?
Thank you very much.
webipsum
CS968 - JESURUN
Re: cwm recovery for rk3188
Originally posted by mustanley View PostI have made a mistake trying to install CWM on T428
Code:u0_a54@android:/ $ su - root@android:/ # cd /mnt/sdcard/Download root@android:/mnt/sdcard/Download # ls AmazonApps-release.apk T428-cwm-recovery.img.zip cwm-recovery.img cwm.sh term-install.zip root@android:/mnt/sdcard/Download # sh cwm.sh cp: flash_image: No such file or directory root@android:/mnt/sdcard/Download #
webipsum
CS968 - JESURUN
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by mustanley View Postthank you, I repeated the steps and it now works. The first time I unzipped term-install.zip it extracted cwm.sh but not flash_image.
black screen on recovery
hello,
i gave the cwm recovery on the neo x7 one more try, since i had always the black screen issue until now.
the issue persists. i am sure that the recovery is installed correctly, but it seems that its something with the HDMI that produces this error. i tried the universal cwm for rk3188 as well with the same problem.
i searched on the net and saw that many devices hat this problem. i tried with a tool called droid@screen (made for htc wildfire) to display the recovery on the pc, without success.
i then installed this TWRP recovery from hereCode:http://dragondevs.com/index.php/topic/1508-recovery-twrp-v2440-for-pipo-m9/
after that i was managed to reboot in recovery without any black screen. i can see all the options, but Of course this recovery does not work, as its for touchscreen and i cannot choose any of the options. but its a proof that the problem its not on my device, but in the cwm.
if the TWRP gives a signal, why does the cwm shows only black screen? Leolas can you help?
Hi hope you can help i have a T-R42 i flashed wasser new ROM for this device but it has stock recovery i tried to flash your cwr with flash tool on the tool everything works fine device reboots but old recovery is still on my device cwr didn't stick so then i tried using the method in this thread with terminal but that don't work says can,t find directory or files checked the script and directories look wrong ?? could you please tell me what i am doing wrong ??
Sent from my Nexus 7 using Tapatalk 4My Device: T-R42
ROM: Wasser ?????
Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
thanks, but it didnt work for me.
i had indeed tried the 1.37 v of RKflashtool to flash the recovery, i flashed it also using the terminal emulator method. The result is the same, unfortmunately the black screen
minix neo x7
ok i managed to boot into recovery with no black screen issue, by using an apk called arctools from arctabletCode:http://www.arctablet.com/assets/tools/arctools/com.arctablet.arctools.apk
could i have a device specific recovery? ifi give you the recovery.img that works on my device, can you make one having not only the ramdisk inside?
Originally posted by meddem View Postok i managed to boot into recovery with no black screen issue, by using an apk called arctools from arctabletCode:http://www.arctablet.com/assets/tools/arctools/com.arctablet.arctools.apk
Parameter file for a cx-921 8*8gb
just a gentle reminder
I hate to even ask - and I know I shouldn't but well you know how it is when you get something in your head that you really want to do - but can't - due to some little technicality that (I in this case) don't know how to fix. I am really really sorry to bug you over this Leolas.
Sorry. I really need to sit in front of pc some hours to put updated all petitions, here in my country there are some festive days, and I am only a few minutes in front of pc, untill Tuesday that my daughter and wife come back to school and work, I don't have time enought, but your request is in my things to do list
There are currently 1869 users online. 0 members and 1869 guests.
