Decided to make a few of my own. More stable, more efficient and (no longer opensource)!
Also, with the versions of the tools, i decided to base it on the latest version of the amlogic tool and increment it by 1.
ALL DOWNLOADS ARE HERE IN A SINGLE PACKAGE(32.6mb)
BE SURE WINDOWS DEFENDER AND ANTIVIRUS DO NOT INTERFERE WITH THE PROGRAMS AND ALL ITS CONTENT!!!
The only thing i request is that my software is not mirrored or uploaded anywhere else
Wanna create your own ROM? Check out my Android guides on Youtube right Here
A donate version is now available so donate HERE and email [email protected] after you have donated to acquire the donate version
Customization Tool
Fixes/Features-
-Removed obsolete functions
-Better tool management
-More information displayed
-Fixed changing bootanimation
-Fixed bootanimation orientation
-Added bootanimation dimensions + FPS are now shown
-Fixed displaying wallpaper
-Fixed ability to change wallpaper
-Fixed ability to display bootlogo
-Apps tab now literally shows all apps.
-Added kernel/recovery tab
-Shortcuts to open certain kernel files added
-Shortcuts to open certain recovery files added
-Ability to convert recovery to TWRP recovery
-Option to open Generic.kl(keymap) file
-Ability to add init.d support(system hook)
-Abillity to compile into TWRP flashable zip
-Added option to choose wipe /data
-Added options to choose what files to write
-Faster EXT4 decompression
-Faster way of splitting update package
-Partition verification added
-Ability to save as project
-Repack to USB burn img
-Change bootvideo
-Enable boot video
-DTB editing
-Add/remove required keys for firmware flashing
-Enable adblocking(Donate version only)
-Full vendor partition support(Donate version only)
-Abillity to modify the internal partition table(Donate version only)
-Unpack/Repack the bootlogo
Much more i have forgot..
Bootloader Console
Fixes/Features-
-Communicate with UBOOT
Burn Card Maker
Fixes/Features-
Formatting happens in the background(no P/Invoke)
Formatting done on seperate thread
Quicker extraction of aml_sdc_burn.UBOOT
Faster file processing
AMLogic Flash Tool
Fixes/Features-
Flash kernel
Flash recovery
Port recovery from device recovery
Port recovery from recovery.img
Port recovery from Upgrade package
Flash after completing port
Backup kernel/recovery to folder
Backup kernel/recovery to flashable.zip
Reboot
Reboot into recovery
Flash zip(coming soon)
Upgrade Info Tool
Fixes/Features-
Basically displaying all needed info about an AMLogic upgrade package
CHANGELOG
Can be found over at XDA-Developers.com
