[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
Originally posted by ricky divjakovski View PostYeah this is really doing my head in, its gotta be something to do with file paths
You need to update your source code. hard to help out when your working on a different version to the source code provided.
Originally posted by Tonian View Post
Whats changed from 3.5 to 4.0? Only issues I've had, have been with 4.0 so it suggests something you've changed
EDIT: there are an odd 1000-2000 lines of code added/changed from 3.5-4.0
i would like to contribute but as I've said before. my knowledge is heavily based round the Basic language but after scanning through your 3.5 Source code, i was surprised by how much i understood. i stopped looking through the code because as mentioned earlier, its old code and you appear to have made a lot of changes in newer versions so ill wait for the new source code.
Think this program(s) will get more attention as the firmware versions move forward as the original customization tool is already failing at Nougat (7.0). id assume it doesn't work at all with Oreo.
Originally posted by Tonian View Posti would like to contribute but as I've said before. my knowledge is heavily based round the Basic language but after scanning through your 3.5 Source code, i was surprised by how much i understood. i stopped looking through the code because as mentioned earlier, its old code and you appear to have made a lot of changes in newer versions so ill wait for the new source code.
Yeah the C# .net 4.0 is very easy to understand and easy to add a GUI, thats why i chose .net
along the line i may make the unpacker class and USB client(will be in v4.5) in raw C or C++
like i said i dont have git installed on my fresh install but if you need the source code i can quickly package and upload to mega for you, feel free to PM me for the link
Originally posted by Tonian View Posti never even thought about the Burning tool as that has always just worked for me. fairly sure 2.0.8 is an old version although not exactly sure what the newer version have added/changed (2.16?)
Can do. thanks.
There is issues, it cant flash anything other than 8.x, fails to load some packages and the occasional crash on flash
There are currently 1798 users online. 0 members and 1798 guests.
