[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
nothing happens when i use the sd card been trying for a while now..it does nothing ..it is been connected with the regular amlogic burning tool but i cant get it flashed,, i tried over 30 different firmware only one works then the box freeze after it starts then after reboot it only goes to the boot logo ..the firmware that worked first will not flash on it again ..dont kno why?
download the firmware from tanix website and then burn it on the sd card using burn sd card tool. Dont use the one on this site that is in the customization tool. i used the one on the atvxperience site and it worked for me. After burning to sd card do the same steps again.
i tried twrp method also but it gives me errors. sd card worked for me. i had the same problem and i used the formware on the tanix site.
Originally posted by hapishyguy View PostI made the rom using this customization tool and put it on the box and its dead now. SO, the ROMS are corrupt using this tool.
Originally posted by hapishyguy View PostThanks..
On the other note, is it possible on TX3 Mini to remove all the apps from the main page and just put two apps
OR remove where the Kodi app is on the left of the main page and out something else there.
Originally posted by soldiaz View Postcould anyone kindly advise howto replace stock launcher within rom?
Originally posted by hapishyguy View PostDoes anyone know of any launcher that is scrollable and only one app at a time. No home screen full of apps. One single line of 3 or 4 apps and the last one on the right is the Apps clicking on which takes you to all the apps.
Originally posted by hapishyguy View PostNone, because I don't know which one can provide a single page single app interface.
I use LightHome on my Boxes but Launcher3 you can place icons where you want for the most part.
There are currently 2822 users online. 0 members and 2822 guests.
