[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
Originally posted by ricky divjakovski View Post
Thanks for the tests, yes its a work in progress.
While on some PC's the tool fails completely, others run it without issue and im stuck here scratching my head, asking myself why?
None the less, still not quite complete, as i get more and more TV boxes im able to perform checks, optimizations, feature editions and debug possible errors in the tool
Its still much more promising than the original tool when it is stable
Good luck trying to tackle the unknown bug. Seems that at least not everyone is effected by the fail issues.
Originally posted by Tonian View Postjust downloaded your source code and it works fine via visual studio's debug.
Tanix TX3 Mini 7.1.2 unpacked.
However, if your able to test, get all the files inside the bin folder of 3.5 and paste them in the bin folder of 4.0.0 overwriting any existing files, then try unpacking/repacking with 4.0
Originally posted by X92-2GB View Post
Donno, if the Microsoft Developer Tools fault with x64 depending on built, or the new system updates with NET. Things are hard to troubleshoot without a similar setup being ran.
Either way this tool is a step in the right direction allowing people to modify AMLogic firmware that is not open source..
This is 3.5 source code, unpacking is not optimized to be repacked.
Same thing. crashes at Kernel.
Originally posted by Tonian View Postcould you upload the 4.0 source code?
i doubt ill be much help with my fairly simple visual basic knowledge.
Originally posted by X92-2GB View PostDonno if Java calls are being done... I find with various apps, I need to load a big library of Java revisions, mainly because of support ended long before the current Java.
I all the versions of .net framework installed. 3.5, 4.0, 4.5 and 5.0
Originally posted by Tonian View Postnot sure if possible but anyway to get access to the IR Codes for power on/off?
obviously can get access to the android IR codes in the remote.conf but this doesn't control the IR commands for power on/off.
i worry that its hardcoded to the IR receiver rather than part of firmware.
Thanks again, Ricky
Having a problem unpacking my ROMs at any combination of levels; stuck at "Unpacking Level 1 (Splitting package)" infinitely when running from an ext hd. When I copy the AMLTools folder locally and run from my desktop, it crashes whether under user context or admin context
Ideas? Win7, 64-bit
There are currently 1895 users online. 0 members and 1895 guests.
