[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
Originally posted by ricky divjakovski View Post
Im working very hard to get the logo unpack/repacking done, im having issues finding the original res_pack.exe file, i found it the other day but lost it, now i cant remember where i found it
BTW, can I get a your test version of v5.0, which had fixes for Android v5.x to 8.x?
Cheers,
Originally posted by mrish View Post
Originally posted by bullgates View PostWhen unpacking the firmware of a R-TV-BOX Pro something in the kernel seems to fail and all the ramdrives are empty.
This ROM seems to use qca9377 wifi drivers, this means it seems compatible with the H96pro plus hardware.
Hey ricky divjakovski , thank you for all your great work. If you allow me to test with that ROM, I'll be glad to do it. Have a great day.
V5 is just about done, all issues are fixed
NOTE: For anyone having issues with V5.0.0 when i release it, if your firmware doesnt unpack further than level 1, you have an encrypted firmware and further unpacking cannot be done.
Encrypted firmwares cannot and will not be supported by the tool, but its safe to say V5.0.0 will work bugfree, and if it doesnt, we have logs to fix the issue, but me and my testers have gone through 12 betas of V5.0.0 from windows 7-windows 10
Current issue list
-Doesnt support encrypted firmwares
-Windows 7 doesnt support unpacking/repacking update zips, while windows 8-10 works fine(cygwin binary issues that are out of my reach)
-Logo repacking is still not done, further study on how the checksum for the img is generated is needed and most online info is obsolete. i did have amlogics respack.exe(respack.dll before it was turned into a lib) but i misplaced it and cannot relocate it
But for anyone interested in the current changelog of V5.0.0 you can find it here -
---------------------------->> v5.0.0 <<----------------------------
Added bootloader console tool
Added Amlogic USB Api
Added AMLogger(My Amlogic tool logging class)
Added AMLUnpacker V2
Updated CoolADB client
Tools now run COMPLETELY native
The source code is no longer released to the public
Included EOLUtil(my utillity to convert EOL chars between formats)
---[AMLogic Flash Tool]---
Fixed ADB connectivity issues
Fixed recovery porting issues
Added recovery porting for S905W devices
---[Unpacker Class]---
-Splitting is now done with official binary
-Now includes kernel unpacking/repacking
-Now includes converting file_contexts
-Much quicker in operation
-Quicker method of checking CRC checksums
-Added abillity to split/append the DTB partition
-Added abillity to convert dtb files to and from text
---[Customization Tool]---
-Fixed clearing tmp folder crash
-Removed the need for JRE
-Fixed issues of unpacking kernel on some computers
-Cleaned up keernel unpacking/repacking
-Added background support for Tanix3
-Added background support for H96 Pro H3
-Fixed replacing recovery/kernel bug(not valid ramdisk)
-Fixed Saving/exporting/loading level 1 unpacks
-Support added for 5.x.x - 7.x.x
-Fixed system length(file size) issue
-Removed add init.d support(problematic for some Android versions)
-Removed port recovery from only this tool, flash tool still has it
-Fixed permissions issue
-Internal checks for successful kernel unpacking/packing added
-Internal checks for successful recovery unpacking/packing added
-Internal checks for successful system unpacking/packing added
-Internal checks for successful dtb unpacking/packing added
-Option to edit remote.conf
-Added support for unpacking meson1.dtb
-Added DTB tab
-Added DTB editor
-Auto DTB line conversion
-DTB editor with search capabillities
-DTB editor with Obsidian theme/syntax highlighting
-Tool now searched for suppoted preinstall directories
-Fixed replace recovery/kernel issue
-Fixed "No changes applied" issue with system
-Full windows 7 support now added
-Added oem partition unpacking support
-Added vendor partition unpacking support
-Updated way of repacking to zip file
-Fixed wallpaper apk still in use
-Added partial packing for upgrade package
-Added partial packing for upgrade zips
-Stronger compression method(avg pack time 1-3 - 4min, 5-7 - 10min, 8-9 - 20min+)
There are currently 3061 users online. 2 members and 3059 guests.
