[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
Originally posted by sagert View PostThere unpack.level1 it is necessary to press and open that it worked.
thanks in advance
Originally posted by plikmuny View Post
Can you elaborate more please? What settings you did and how you started from the beginning? I tried many android tools, none worked completely. I have windows 7 32bit
thanks in advance
The instructions are the same.Especially since I write english with translation.Take your firmware and rename it to x.img.Put it in the in folder.Press unpack.level1 and open it 1 level will be unpacked in the terminal.Press unpack.level2 and open it the 2nd level will be unpacked in the terminal.Next edit level2.There you edit system, vendor and more...Now collect level 2.Click repack.level2 and open it.Next collect 1 level.Click repack.level1 and open it ..You will find the finished firmware in the out folder.
Originally posted by raruba View Post
Its surely not working like that for me....thats for sure. Only thing it does for me is make a folder called level1 and if u click unpack level 2, a folder called level 2, nothing in either folder
Video of how the XVortex kitchen works.
Originally posted by sagert View PostAnother link to a video of the work of the XVortex kitchen.
https://anonfiles.com/f9qdG070pd/XVo...tchen_work_zip
I tried exactly as it shows, level1 unpacked fine, level2 just flashes a black screen and puts a level2 folder in the kitchen folder......?????
Or maybe another program.
Perhaps, when opening the 2nd level of the firmware, Windows detected some kind of harmful program in the firmware. I had UTorrent, for example. I had to click and open clean_up to clear the folder and repeat the steps again to open the firmware.
I use only 1 level in this kitchen. To edit system, vendor,boot,recovery I use this program:
There are currently 1999 users online. 0 members and 1999 guests.
