[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
I was informed about possible mistakes in the kitchen.if you make pack_level2> tt those. reassign the output, the errors can be read on the screen. Now I have just that case:
J:\JAW_AOSP0391>01_pack_level2.bat >tt
make_ext4fs Vortex edition
[system/system/preinstall/CastReceiver/CastReceiver.133t (1).apk] not found in canned fs_config, using defaults
[system/system/preinstall/MoreShortcuts/More Shortcuts_JAW.apk] not found in canned fs_config, using defaults
[system/system/preinstall/ZMediaProxy/Z Media Proxy-org.tv.zmpa-2-0.0.38.apk] not found in canned fs_config, using defaults
error: ext4_allocate_best_fit_partial: failed to allocate 53 blocks, out of space?
Failed to create image level1\system.PARTITION, removing it
Unexpected appearance: exit.
Originally posted by sagert View PostIn general, the first raruba, most likely, does not have enough disk space. The second soldiaz has a System too large. Can edit \ level2 \ system_size But it's better to delete something unnecessary
Originally posted by soldiaz View Post
Mmh I guess something went wrong. No issues repacking STOCK fw...works really good, will give the FW to the community in couple of minutes. Made just few modifications since all other customs are based on older stock and these have BT issues :-( if someone could assist on converting to ATV youre welcome! I dont have that experience - the good side: there are lots of ATV yet, so shouldnt be an issue!
I do not know if this is suitable for many tv boxing for android 9.
magisk atv module for conversion of aosp to atv.
I am interested in putting some apk in system folder. I tried and put entries into file_context with rights. But did not work :-(
Ive experienced that error as well but I dont know what it is...all works as should
Originally posted by sagert View PostHow does kitchen XVortex v 4 work. To convert aosp firmware to atv. Part 1 and part 2.
https://youtu.be/rcpWvIibtSk
There are currently 1724 users online. 0 members and 1724 guests.
