[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
Guest
??????How to change the size of system by means of kitchen ?Vortex v 4. It is if in dtb only 1 dtb:
??????https://youtu.be/dmdGjq-FH_o
One more xdtc program is needed here. It can be downloaded here:
xdtc (mediafire.com)
There is a little Ukrainian language. I use it in windows.
Okay guys good news I managed to modify xVortex kitchen v4 . Working in Windows 10 so far I changed logo patrician. Took apps from system on a firmware pie. Testing firmware on my Minix neo u9h and he's booting normal I see the logo change software so good I'm doing more tests to make sure before I release it
mmh, could you supply Russian manual in UTF-8 format as well? level1.txt, 2, 3...not readable:
1) äëÿ ðà ñïà êîâêè ïðîøèâêè, áåðåì UBT Image (.img) ôà éë è êëà äåì åãî â ïà ïêó in.
Åñëè èìÿ çà ìîðî÷åÃÃîå, ïåðåèìåÃîâûâà åì âî ÷òî-òî ïðîñòîå Ãà ïðèìåð ax95.img
Guest
Originally posted by soldiaz View Post1) äëÿ ðà ñïà êîâêè ïðîøèâêè, áåðåì UBT Image (.img) ôà éë è êëà äåì åãî â ïà ïêó in.
1) To unpack the firmware, take the UBT Image (.img) file and put it in the folder in. If the img is free, we can change it now, for example, ax95.img
Guest
Originally posted by soldiaz View PostNo ATV conversion kit has been removed!
Script to convert AOSP firmware Ugoos (TOX1) to ATV
Test, one-button version based on the new base.
We unsubscribe about the results.
1) Put the AOSP .img firmware file in the <in> folder
2) Run _aosp2atv.bat
3) Pick up the finished ATV .img file in the <out> folder OR ... just drop the AOSP .img file to _aosp2atv.bat
Enjoy.
There are currently 2836 users online. 1 members and 2835 guests.
