[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
It is written about her here:
- Added third level of unpacking / packaging (boot, recovery, logo, devicetree) - Added the ability to create full ota zip (fota) from level1 (Java is required).- Added third level of unpacking / packaging (boot, recovery, logo, devicetree) - Added the ability to create full ota zip (fota) from level1 (Java is required).
Instructions:
First level
Kitchenette to work with the first level of Amlogic firmware
Instructions:
1) to unpack the firmware, take the UBT Image (.img) file and put it in the in folder.
If the name is confusing, rename it to something simple for example ax95.img
2) click _unpack_level1.bat
3) in the level1 folder, replace / edit the files:
aml_sdc_burn.UBOOT- bootloader, file 1
DDR.USB - bootloader, file 2.change simultaneously with f.1
boot.PARTITION - kernel
_aml_dtb.PARTITION - kernel settings file
recovery.PARTITION - recovery
logo.PARTITION - logo (sometimes depends on the bootloader).
odm.PARTITION -
product.PARTITION -
system.PARTITION -
vendor.PARTITION - These 4 sections contain the system files.
4) click _pack_level1.bat, in the out folder we take the finished img file.
to create a full OTA, click _pack_level1_fota.bat
5) Enjoy.
Second level
Kitchenette for working with the second level of firmware Amlogic
Instructions:
1) to work with the second level, you must unpack level 1 (see level1.txt)
2) click _unpack_level2.bat
3) in the level2 folder, replace / edit the files in the folders:
system - the system section
vendor - the vendor section
product - product section
odm - odm section
If you add new files or folders that require special rights
(by default, new files and folders are assigned privileges 0644 and 0755 during packing)
then register these rights in the * _fs_config files.
* _File_contexts files are needed to register SELinux privileges
And * _size files set the size of this or that partition.
4) click _pack_level2.bat
5) then pack level 1 (click _pack_level1.bat, see level1.txt)
6) Enjoy.
Third level
Kitchenette to work with the third level of firmware Amlogic
Instructions:
1) to work with the third level, you must unpack level 1 (see level1.txt)
2) click _unpack_level3.bat
3) in the level3 folder, replace / edit the files in the folders:
boot - boot partition (kernel)
recovery - recovery section
logo - logo section
devtree - devicetree section
4) click _pack_level3.bat
6) Enjoy.
Instructions:
First level
Instructions:
odm.PARTITION -
product.PARTITION -
system.PARTITION -
5) Enjoy.
Second level
Instructions:
odm - odm section
6) Enjoy.
Third level
Instructions:
logo - logo section
6) Enjoy.
Originally posted by raruba View Post
Wow, these instructions are all chinese to me..lol....I can unpack level 1 and thats it.
video of how the XVortex kitchen works.
Not sure what your even saying????? Only thing it does for me is create a folder (level 1 and or level 2) when u click unpack level 1 or level 2
Originally posted by antonio6o6 View Post
When you trying to extract level 1 do it give you a error if giving you an error can you tell me what kind of error because I did have a problem like that at first was missing some drivers but I don't know if if you getting that kind of error let me know
Level 1 unpacks OK. Level 2 just gives me a folder called level 2....that's it, nothing in the level 2 folder.
I copied this too files Open kitchen v3 and paste it . Not sure this is your case but it worth a try. If you don't know where to get this two files go to this program. AMlogic unpacker by mayan and get it from there
msvcr100.dll
msvcp100.dll
If you delete XVortex kitchen v3. And download it again with out any modification. because I did not did any modification to that unpack L 2. The thing I did was
msvcr100.dll
msvcp100.dll
Originally posted by soldiaz View Postmmh worked but repacked SYSTEM.img is corrupt? Tried repack Slimbox
There are currently 3143 users online. 1 members and 3142 guests.
