Android is constantly being updated...
[08/03/2019] AMlogic Tools [6.0.0][A new milestone][Donate Version Available]
AMlogic Tools [7.1.0] Donate version is free now on Ricky's site under products
Ricky's site
thanks Ricky
Originally posted by MgmGtx View PostAMlogic Tools [7.1.0] Donate version is free now on Ricky's site under products
Ricky's site
thanks Ricky
Its giving me error in extracting Vendor / System file from Image file.
Originally posted by plikmuny View Post
It doesnt work... waste of time.
Originally posted by raruba View Post
Can't read the instructions, doesn't work either
Instructions:
First level
Kitchenette to work with the first level of Amlogic firmware
Instructions:
1) to unpack the firmware, take the UBT Image (.img) file and put it in the in folder.
If the name is confusing, rename it to something simple for example ax95.img
2) click _unpack_level1.bat
3) in the level1 folder, replace / edit the files:
aml_sdc_burn.UBOOT- bootloader, file 1
DDR.USB - bootloader, file 2.change simultaneously with f.1
boot.PARTITION - kernel
_aml_dtb.PARTITION - kernel settings file
recovery.PARTITION - recovery
logo.PARTITION - logo (sometimes depends on the bootloader).
odm.PARTITION -
product.PARTITION -
system.PARTITION -
vendor.PARTITION - These 4 sections contain the system files.
4) press _pack_level1.bat, in the out folder we take the finished img file.
5) Enjoy.
Second level
Kitchenette for working with the second level of firmware Amlogic
Instructions:
1) to work with the second level, you must unpack level 1 (see level1.txt)
2) click _unpack_level2.bat
3) in the level2 folder, replace / edit the files in the folders:
system - the system section
vendor - the vendor section
product - product section
odm - odm section
If you add new files or folders that require special rights
(by default, new files and folders are assigned privileges 0644 and 0755 during packing)
then register these rights in the * _fs_config files.
* _File_contexts files are needed to register SELinux privileges
And * _size files set the size of this or that partition.
4) click _pack_level2.bat
5) then pack level 1 (click _pack_level1.bat, see level1.txt)
6) Enjoy.
Originally posted by sagert View Post
Simple translation of instructions:
Instructions:
First level
Instructions:
odm.PARTITION -
product.PARTITION -
system.PARTITION -
5) Enjoy.
Second level
Instructions:
odm - odm section
6) Enjoy.
Step 1 doesnt complete at all.
i had other Package, where atleast step 1 is successful, but it fails to complete step 2 due to unknown reason.
So i request anyone who has successfully unpacked , edited and repacked am amlogic .img file to share his files and the Operating System here.
Tried that many times. it just doesnt work. i dont know what is wrong in the files.
There are currently 6677 users online. 2 members and 6675 guests.
