That happen exatly to my first one! I think that i am going to open this second one and take photos to show were did they put the glue in the soldering points(2 or 3 points), that proves this android box was with some kind of hardware problem. I think it is anti-static eletrical conductive glue. Try contact alfawise, ask for warranty!
Alfawise A8 TV BOX Rockchip 3229 Android 8.1 - 2/16GB 2.4G WiFi 100Mbps Support 4K H.265
I ordered a different box (Amlogic) hopefully it produces better results. I do appreciate your help though Bnt007!
ill hold onto the box and see what Alfawise says about a warranty
Originally posted by JG420 View PostI ordered a different box (Amlogic) hopefully it produces better results... ll hold onto the box and see what Alfawise says about a warranty
I did the same, gave up on the Alfawise A8 TV Box, too much hassle and ordered a box with an Amlogic 905W. It is indeed a much better choice imho and now I'm fully aware of how "underpowered" RK3229 devices are. Everything feels snappier, apps like youtube start a lot faster and the soc produces less heat. No compatibility issues so far as with the RK3229. Amlogic powered devices run a lot cooler - in every sense ;-)
Hope you are happy with your new box, although it seems to me every box has issues, especially in this price range...
Originally posted by Vienna View PostHello everybody,
new firmware with hopefully some bugfixes for the Alfawise A8 from the Gearbest-support:
https://drive.google.com/drive/folde...ZxNYsqvjdiZR7-
If anyone finds a ROM or a way to install the 'TVStock' flavor of OpenGapps, please , please post here!! Thank you
Yes, the annoying wifi-issue should be fixed with this firmware. Nonetheless if you have the possibility to connect the box via LAN, it is the much better option. The wifi-performance of the A8 is pretty poor and somehow slows down the box. Meanwhile there's also a new A8 Pro 5G available. It offers additional 5Ghz-wlan but otherwise it seems to be pretty much the same box with mostly the same hardware.
PS: One more difference: The A8 Pro 5G comes with 2 USB-ports and not with 4 as the A8
I?ve tried many times to side load all Android TVStock apps, libs, and permissions and have got very close. Google Play Store leanback I?ve got working, it?s just the TV Launcher and/or Leanback launcher I can?t get to load. When opening, It crashes or display black screen. Anyone know any tricks to manually install the Leanback launcher?... Or have an updated FW Modding tool for Oreo roms? I can?t seem to locate the file_context to rebuild image.
Originally posted by Vienna View PostYes, the annoying wifi-issue should be fixed with this firmware. Nonetheless if you have the possibility to connect the box via LAN, it is the much better option. The wifi-performance of the A8 is pretty poor and somehow slows down the box. Meanwhile there's also a new A8 Pro 5G available. It offers additional 5Ghz-wlan but otherwise it seems to be pretty much the same box with mostly the same hardware.
Originally posted by Vienna View PostNo changes there, as before the box only goes in sleep-mode when you press the power-button on the remote. There are still no options (as with lots of other boxes) in the menu to configure a real shutdown via power-button.
Root access could be achieved by:then reconnect once booted:shell commands adb connect IP
adb root
adb connect IP
adb disable-verity
adb rebootshell commands adb connect IP
adb root
adb connect IP
adb remount # same as mount -o remount,rw /system
Done! You'll only need to disable-verity once.Last edited by mrlaugh01; 07 January 2019, 19:38.
There are currently 1662 users online. 1 members and 1661 guests.
