Does HDMI-CEC work for you? It seems that it doesn't work with my Samsung TV
Alfawise A8 TV BOX Rockchip 3229 Android 8.1 - 2/16GB 2.4G WiFi 100Mbps Support 4K H.265
How to flash firmware to a rockchip TV box Alfawise A8 using the FactoryTool
(to fix the problem with the loss of wifi when we press the power button on the remote)
Download Firmware link from Gearbest: https://www.gearbest.com/blog/downlo...ware-pack-2965
1.Unzip 2713799 Alfawise A8 TV box upgrade firmware ROM pack.rar
2.Unzip them all their folders and files
3.Move the original folder and subfolders under C: \ or D:\
4.Rename folders and files that have Chinese characters in English characters (with a name you like)
5.Install "DriverAssitant_v4.5" driver on windows 10-8-7. Wait until the install says "install ok"
6.Open "Factory Tool" software
click the Firmware button find and upload the image file
click the Restore button and after the Run button (the button image on the right turns green)
7.Disconnect everything from the TV box (even the power transformer electric current)
8.Behind the TV box is one reset button, this is inside the AV jack, You need to take a toothpick or any non metalic will to press and at the same time conect the usb 4 (near the AV jack) with usb to your pc (A USB male-male cable is needed for this)
then left the reset button free.
The Factory Tool recognizes the TV box downloads the firmware and then checks it (if the drivers are installed correctly)
If everything goes well the Factory Tool writes to us right (under word "success") the result and the time it passed with green letters.
(Τhank you friends from the forum that helped me solve my problem)
Hey Dimkonst, thanks for the instructions.
However, I am having the following issue...
When loading the firmeware into the factory tool v1.52, The program crashes and closes. I used another version 1.39 and i was able to load the firmware onto the TVbox... However, When I power on the box, I am stuck on the boot up screen that says "Android"
Can anyone help?
Originally posted by daniels21 View PostHey dimkonst, I used another laptop with win 10 to do this and the factory tool v1.52 worked. The firmware loaded with no problems. Thank you!
now if only there was a way to power off the box... the power button on the remote only puts it to sleep. any ideas?
Originally posted by Lapis View PostWhat is the version of the latest firmware? I bought the box at Dresslily and it arrived with build "rk322x_box-userdebug 8.1.0 OPM5.171019.019 eng.qiahoy.20181105.194655 release--keys".
Does HDMI-CEC work for you? It seems that it doesn't work with my Samsung TV..
with this firmware the problem with the wifi was solved but I have other problems like losing the wifi keyboard when it's closed the TV box for a few hours,
HDMI-CEC does not work on my Samsung TV
There are currently 2072 users online. 1 members and 2071 guests.
