Alfawise A8 TV BOX Rockchip 3229 Android 8.1 - 2/16GB 2.4G WiFi 100Mbps Support 4K H.265
Originally posted by dimkonst View PostNow the A8 is a bit better, I was having trouble installing the new firmware (it continued to cycle), now I try it, sometimes I lost the mouse, I'll write for you later.
Originally posted by mrlaugh01 View PostRoot access could be achieved by:then reconnect once booted:shell commands adb connect IP
adb root
adb connect IP
adb disable-verity
adb rebootshell commands adb connect IP
adb root
adb connect IP
adb remount # same as mount -o remount,rw /system
Done! You'll only need to disable-verity once.
Originally posted by gary_t View Post
Done root. Installed SuperSu from the playstore app. But after reboot it went into bootloop (can't go beyond ANDROID logo). Any solution to this? (Using A8 pro 5G)
You'll need to short the NAND and reload firmware. The. You can try using systemless SuperSU or Magisk Manager Install MagiskSU and to patch the boot.
Also, Magisk wasn't working unfortunately. I have now dropped the idea to install SuperSu. I only wanted to install Viper4Android and looks like I need to wait for experimentation till lockdown gets over
I got this ROM or a similar one working on my RK3229 with WiFi 6051p (though the wifi didn't turn on but I use only ethernet anyway).
The only point for and my remote control, is that any ROM that worked 8.1, 7.1.2, 6.0.1 and others I never had remote control to turn the device on and off.
So I had to go back to 5.1.1 which seems faster at least (the box is pretty old 1GB/8GB).
Any ideas if I can get the remote control working from my 5.1.1 and stick to another ROM?
Help! After a failed attempt at flashing the 9.0 ROM I got stuck in a boot loop (Alfawise A8 2G/16G). Here's what I've tried:
- disconnect everything
- toothpick on button (confirmed!)
- connect USB4 to USB PC Port (using male-to-male cable)
- remove toothpick and connect power adapter
After doing this there's a red light for around 8 seconds then there's a flashing blue light. FactoryTool doesn't recognize the box (I tried several PC USB ports)
Anyone knows how to fix this?
Thanks in advance!
Originally posted by rcpinho View PostHelp! After a failed attempt at flashing the 9.0 ROM I got stuck in a boot loop (Alfawise A8 2G/16G). Here's what I've tried:
Thanks in advance!
Also, one step is in the incorrect order:
It has to be CONNECT USB CABLE AND REMOVE THE TOOTHPICK.
There are currently 3849 users online. 1 members and 3848 guests.
