{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
@NayamAmarshe I will be VERY pleased if this becomes the base that evolves into ATVexperience for S905x as I have two MXQ Pro+ and one A95X (all S905X, 2Gb boxes) and ATVexperience means Netflix full HD AND Google Cast.. I'll donate for sure if I see that happen!!
Hey Guys, Newbie user here and need this badly.
I owned a - "MXQ Pro 4k S905x r329q v3.0 -- 1/8, Nougat 7.1.2"
Problem is current version is running very slow and laggy also random errors are popping up, so I think it's the version who run very slow.
Will this one work on my tv box?
Kindly, enlighten me what will be my first step
Will appreciate any help and advice. Thanks a lot OP for the update
Originally posted by joelupet View PostHey Guys, Newbie user here and need this badly.
I am interesting to install Android TV on my MXQ PRO+ which is a s905x running android 7.1.2.
I download the S905X_ATV_V2.7.img file and unfortunatly the flash with usb burner tool stops at 98% with an error. If I start the box I got the google boot screen and nothing else after a while (many hours).
Below log of the flash.
I try may option to burn with the same result.
Any ideas ?
thanks a lot
regards
[12:00:37 870][Global][Inf]--User click open button
[12:00:55 507][Global][Inf]--Image path D:\Users\gprgl\Downloads\S905X_ATV_V2.7.img
[12:00:55 507][Global][Inf]--OpenImg D:\Users\gprgl\Downloads\S905X_ATV_V2.7.img
[12:00:59 584]Parse platform.conf
[12:00:59 600][Global][Inf]--Parsing burning package
[12:00:59 600][Global][Inf]--Load configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp
[12:00:59 600][Global][Inf]--Parse burning configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp\burn_config.xm l
[12:00:59 600][Global][Inf]--Get burning key
[12:03:05 215][Global][Inf]--User click start button
[12:03:05 215][Global][Inf]--SetErase
[12:03:05 215][Global][Inf]--Enable burning 1
[12:03:05 215][Global][Inf]--Scan usb device
[12:03:05 215][Global][Inf]--Aml scan WorldCup Device
[12:03:05 215][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[12:03:05 215][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_8216103c& rev_21#3&11583659&1&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[12:03:05 215][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&34f2690e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[12:03:05 215][Global][Inf]-------->[Port0]\\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[12:03:05 215][Global][Inf]-------->[Port1]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port2]Other device
[12:03:05 215][Global][Inf]-------->[Port3]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port4]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port5]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port6]Other device
[12:03:05 215][Global][Inf]-------->[Port7]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port8]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port9]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port10]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port11]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port12]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port13]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port14]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port15]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port16]NoDeviceConnected
[12:03:05 215][Global][Inf]-------->[Port17]NoDeviceConnected
[12:03:05 215][Global][Inf]--Scan USB host controller complete
[12:03:05 215][Global][Inf]--Update data center with HubMap
[12:03:05 215][Global][Inf]--Update hub1 device data
[12:03:05 215][Global][Inf]--Update HUB1-1 \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[12:03:05 277][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000004b4
[12:03:05 340][HUB1-1][Inf]--CloneImageProxy
[12:03:05 340][Global][Inf]--OpenImg D:\Users\gprgl\Downloads\S905X_ATV_V2.7.img
[12:03:05 340][HUB1-1][Inf]--Connect path=Contrôleur d’hôte compatible xHCI USB/P0/P0
[12:03:05 340][HUB1-1][Inf]--Start burning...
[12:03:05 402][HUB1-1][Inf]--------------ERASE BOOTLOADER------------
[12:03:05 918][HUB1-1][Inf]--0-7-0-16
[12:03:05 918][HUB1-1][Inf]--Identify status success
[12:03:05 918][HUB1-1][Inf]-- low_power
[12:03:05 918][HUB1-1][Inf]--Low power command success
[12:03:05 918][HUB1-1][Inf]--Read low power success
[12:03:05 918][HUB1-1][Inf]--bootloader_is_old
[12:03:05 918][HUB1-1][Inf]--Bootloader command success
[12:03:05 918][HUB1-1][Inf]--Bootloader is old
[12:03:05 918][HUB1-1][Inf]--erase_bootloader
[12:03:05 934][HUB1-1][Inf]--Erase command success
[12:03:05 934][HUB1-1][Inf]--Read erase status success
[12:03:05 934][HUB1-1][Inf]--reset
[12:03:05 934][HUB1-1][Inf]--reset command success
[12:03:06 949][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[12:03:06 949][Global][Inf]--Scan usb device
[12:03:06 949][Global][Inf]--Aml scan WorldCup Device
[12:03:06 949][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[12:03:06 949][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_8216103c& rev_21#3&11583659&1&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[12:03:06 949][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&34f2690e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[12:03:06 949][Global][Inf]--Scan USB host controller complete
[12:03:06 949][HUB1-18][Inf]--Update device path
[12:03:06 996][HUB1-1][Inf]--Device is removed
[12:03:08 348][Global][Inf]--Catch DBT_DEVICEARRIVAL
[12:03:08 348][Global][Inf]--Scan usb device
[12:03:08 348][Global][Inf]--Aml scan WorldCup Device
[12:03:08 348][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[12:03:08 348][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_8216103c& rev_21#3&11583659&1&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[12:03:08 348][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&34f2690e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[12:03:08 348][Global][Inf]-------->[Port0]\\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[12:03:08 348][Global][Inf]--Scan USB host controller complete
[12:03:08 348][Global][Inf]--Update data center with HubMap
[12:03:08 348][Global][Inf]--Update hub1 device data
[12:03:08 348][Global][Inf]--Update HUB1-1 \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
12:03:08 410][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000844
[12:03:08 476][HUB1-1][Inf]-------------Download DDR.USB-----------
[12:03:08 476][HUB1-1][Inf]--2-4-0-0
[12:03:08 476][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[12:03:08 991][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
[12:03:09 511][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[12:03:10 031][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
[12:03:10 536][HUB1-1][Inf]--Write initial succeed
[12:03:10 536][HUB1-1][Inf]--Upload encrypt at 0xc8100228
[12:03:10 536][HUB1-1][Inf]--ulValue = 0xadfc318c
[12:03:10 536][HUB1-1][Inf]--Read encrypt value succeed
[12:03:10 536][HUB1-1][Inf]--Transfer complete
[12:03:10 536][HUB1-1][Inf]--Run at address 0xd9000000
[12:03:10 536][HUB1-1][Inf]--RunInRam succeed
[12:03:10 771][HUB1-1][Inf]--2-4-0-0-0-1-0-0
[12:03:10 771][HUB1-1][Inf]--CheckFileRunState succeed
[12:03:10 771][HUB1-1][Inf]--runResult:0x 0,paraMagic:0x7856efab
[12:03:10 771][HUB1-1][Inf]--ddrCapacity:0x 400
[12:03:10 771][HUB1-1][Inf]--ulValue = 0xadfc318c
[12:03:10 771][HUB1-1][Inf]--Download UBOOT.USB buffer at 0x0200c000
[12:03:10 911][HUB1-1][Inf]--Transfer complete
[12:03:11 130][HUB1-1][Inf]--2-4-0-0-0-1-0-0
[12:03:11 130][HUB1-1][Inf]--Download DDR.USB buffer at 0xd9000000
[12:03:11 130][HUB1-1][Inf]--Transfer complete
[12:03:11 130][HUB1-1][Inf]--DownCheckPara succeed
[12:03:11 130][HUB1-1][Inf]--Run at address 0xd9000000
[12:03:11 177][HUB1-1][Inf]--ReadCheckPara succeed
[12:03:11 177][HUB1-1][Inf]--2-4-0-0-0-1-0-0
[12:03:11 177][HUB1-1][Inf]--ulValue = 0xadfc318c
[12:03:11 177][HUB1-1][Inf]--Download DDR.USB buffer at 0xd9000000
[12:03:11 177][HUB1-1][Inf]--Transfer complete
[12:03:11 192][HUB1-1][Inf]--DownRunPara succeed
[12:03:11 192][HUB1-1][Inf]--2-4-0-0-0-1-0-0
[12:03:11 192][HUB1-1][Inf]--Run at address 0xd9000000
[12:03:12 536][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[12:03:12 536][Global][Inf]--Scan usb device
[12:03:12 536][Global][Inf]--Aml scan WorldCup Device
[12:03:12 551][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[12:03:12 551][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_8216103c& rev_21#3&11583659&1&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[12:03:12 551][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&34f2690e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[12:03:12 551][Global][Inf]-------->[Port0]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port1]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port2]Other device
[12:03:12 551][Global][Inf]-------->[Port3]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port4]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port5]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port6]Other device
[12:03:12 551][Global][Inf]-------->[Port7]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port8]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port9]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port10]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port11]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port12]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port13]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port14]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port15]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port16]NoDeviceConnected
[12:03:12 551][Global][Inf]-------->[Port17]NoDeviceConnected
[12:03:12 551][Global][Inf]--Scan USB host controller complete
[12:03:12 551][Global][Inf]--Update data center with HubMap
[12:03:12 551][Global][Inf]--Update hub1 device data
[12:03:12 551][Global][Inf]--Update HUB1-1
[12:03:12 551][HUB1-1][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-2
[12:03:12 551][HUB1-2][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-3
[12:03:12 551][HUB1-3][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-4
[12:03:12 551][HUB1-4][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-5
[12:03:12 551][HUB1-5][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-6
[12:03:12 551][HUB1-6][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-7
[12:03:12 551][HUB1-7][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-8
[12:03:12 551][HUB1-8][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-9
[12:03:12 551][HUB1-9][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-10
[12:03:12 551][HUB1-10][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-11
[12:03:12 551][HUB1-11][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-12
[12:03:12 551][HUB1-12][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-13
[12:03:12 551][HUB1-13][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-14
[12:03:12 551][HUB1-14][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-15
[12:03:12 551][HUB1-15][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-16
[12:03:12 551][HUB1-16][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-17
[12:03:12 551][HUB1-17][Inf]--Update device path
[12:03:12 551][Global][Inf]--Update HUB1-18
[12:03:12 551][HUB1-18][Inf]--Update device path
[12:03:12 567][HUB1-1][Inf]--Device is removed
[12:03:13 830][Global][Inf]--Catch DBT_DEVICEARRIVAL
[12:03:13 830][Global][Inf]--Scan usb device
[12:03:13 830][Global][Inf]--Aml scan WorldCup Device
[12:03:13 830][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[12:03:13 830][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_8216103c& rev_21#3&11583659&1&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[12:03:13 830][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&34f2690e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[12:03:13 834][Global][Inf]-------->[Port0]\\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[12:03:13 834][Global][Inf]-------->[Port1]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port2]Other device
[12:03:13 834][Global][Inf]-------->[Port3]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port4]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port5]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port6]Other device
[12:03:13 834][Global][Inf]-------->[Port7]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port8]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port9]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port10]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port11]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port12]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port13]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port14]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port15]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port16]NoDeviceConnected
[12:03:13 834][Global][Inf]-------->[Port17]NoDeviceConnected
[12:03:13 834][Global][Inf]--Scan USB host controller complete
[12:03:13 834][Global][Inf]--Update data center with HubMap
[12:03:13 834][Global][Inf]--Update hub1 device data
[12:03:13 834][Global][Inf]--Update HUB1-1 \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[12:03:13 834][HUB1-1][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-2
[12:03:13 834][HUB1-2][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-3
[12:03:13 834][HUB1-3][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-4
[12:03:13 834][HUB1-4][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-5
[12:03:13 834][HUB1-5][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-6
[12:03:13 834][HUB1-6][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-7
[12:03:13 834][HUB1-7][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-8
[12:03:13 834][HUB1-8][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-9
[12:03:13 834][HUB1-9][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-10
[12:03:13 834][HUB1-10][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-11
[12:03:13 834][HUB1-11][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-12
[12:03:13 834][HUB1-12][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-13
[12:03:13 834][HUB1-13][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-14
[12:03:13 834][HUB1-14][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-15
[12:03:13 834][HUB1-15][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-16
[12:03:13 834][HUB1-16][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-17
[12:03:13 834][HUB1-17][Inf]--Update device path
[12:03:13 834][Global][Inf]--Update HUB1-18
[12:03:13 834][HUB1-18][Inf]--Update device path
[12:03:13 868][HUB1-1][Inf]--Device is connected
[12:03:13 868][HUB1-1][Inf]--Close device handle 0x00000844
[12:03:13 930][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&2e5849b4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000007f4
[12:03:18 985][HUB1-1][Inf]--0-7-0-16
[12:03:18 985][HUB1-1][Inf]--CheckFileRunState succeed
[12:03:18 985][HUB1-1][Inf]-- low_power
[12:03:18 985][HUB1-1][Inf]--Send command success
[12:03:18 985][HUB1-1][Inf]--Read command status success
[12:03:18 985][HUB1-1][Inf]-------------Download meson1.dtb-----------
[12:03:18 985][HUB1-1][Inf]--Enc(0xadfc318c)
[12:03:18 985][HUB1-1][Inf]-- download mem dtb normal 90112
[12:03:18 985][HUB1-1][Inf]--Send download command success
[12:03:19 001][HUB1-1][Inf]--Read command status success
[12:03:19 016][HUB1-1][Inf]--Transfer complete
[12:03:19 016][HUB1-1][Inf]--Send download get_status command succeed
[12:03:19 016][HUB1-1][Inf]--get_status success
[12:03:19 532][HUB1-1][Inf]-------------ERASE FLASH-----------
[12:03:19 532][HUB1-1][Inf]--disk_initial 1
[12:03:19 532][HUB1-1][Inf]--Send command success
[12:03:31 482][HUB1-1][Inf]--Read command status success
[12:03:31 482][HUB1-1][Inf]-------------Download _aml_dtb.PARTITION-----------
[12:03:31 482][HUB1-1][Inf]--0-7-0-16
[12:03:31 482][HUB1-1][Inf]--download store _aml_dtb normal 90112
[12:03:31 482][HUB1-1][Inf]--Send download command success
[12:03:31 498][HUB1-1][Inf]--Read command status success
[12:03:31 685][HUB1-1][Inf]--Transfer complete
[12:03:31 685][HUB1-1][Inf]--Send download get_status command succeed
[12:03:31 701][HUB1-1][Inf]--get_status success
[12:03:31 701][HUB1-1][Inf]--verify sha1sum 78813f7b79d754181bbef75515124fa52fbc341a
[12:03:31 701][HUB1-1][Inf]--Send verify cmd succeed
[12:03:31 716][HUB1-1][Inf]--Get verify status success
[12:03:32 232][HUB1-1][Inf]-------------Download boot.PARTITION-----------
[12:03:32 232][HUB1-1][Inf]--0-7-0-16
[12:03:32 232][HUB1-1][Inf]--download store boot normal 9074688
[12:03:32 232][HUB1-1][Inf]--Send download command success
[12:03:32 247][HUB1-1][Inf]--Read command status success
[12:03:33 232][HUB1-1][Inf]--Transfer complete
[12:03:33 232][HUB1-1][Inf]--Send download get_status command succeed
[12:03:33 232][HUB1-1][Inf]--get_status success
[12:03:33 247][HUB1-1][Inf]--verify sha1sum 34ecce51ca3ee729b00bd4282aa1d5e2bf7dfea7
[12:03:33 247][HUB1-1][Inf]--Send verify cmd succeed
[12:03:33 653][HUB1-1][Inf]--Get verify status success
[12:03:34 169][HUB1-1][Inf]-------------Download logo.PARTITION-----------
[12:03:34 169][HUB1-1][Inf]--0-7-0-16
[12:03:34 169][HUB1-1][Inf]--download store logo normal 5048640
[12:03:34 169][HUB1-1][Inf]--Send download command success
[12:03:34 185][HUB1-1][Inf]--Read command status success
[12:03:34 731][HUB1-1][Inf]--Transfer complete
[12:03:34 731][HUB1-1][Inf]--Send download get_status command succeed
[12:03:34 731][HUB1-1][Inf]--get_status success
[12:03:34 731][HUB1-1][Inf]--verify sha1sum cd008e168c521304a1c761777291d3b1e32c34da
[12:03:34 731][HUB1-1][Inf]--Send verify cmd succeed
[12:03:34 966][HUB1-1][Inf]--Get verify status success
[12:03:35 481][HUB1-1][Inf]-------------Download recovery.PARTITION-----------
[12:03:35 481][HUB1-1][Inf]--0-7-0-16
[12:03:35 481][HUB1-1][Inf]--download store recovery normal 13178880
[12:03:35 481][HUB1-1][Inf]--Send download command success
[12:03:35 497][HUB1-1][Inf]--Read command status success
[12:03:36 918][HUB1-1][Inf]--Transfer complete
[12:03:36 918][HUB1-1][Inf]--Send download get_status command succeed
[12:03:36 934][HUB1-1][Inf]--get_status success
[12:03:36 934][HUB1-1][Inf]--verify sha1sum 0435b5be7bac33535ca4a1ae0bb0e94f408ec3ee
[12:03:36 934][HUB1-1][Inf]--Send verify cmd succeed
[12:03:37 512][HUB1-1][Inf]--Get verify status success
[12:03:38 027][HUB1-1][Inf]-------------Download system.PARTITION-----------
[12:03:38 027][HUB1-1][Inf]--0-7-0-16
[12:03:38 027][HUB1-1][Inf]--download store system sparse 978346452
[12:03:38 027][HUB1-1][Inf]--Send download command success
[12:03:38 043][HUB1-1][Inf]--Read command status success
[12:05:32 079][HUB1-1][Inf]--Transfer complete
[12:05:32 079][HUB1-1][Inf]--Send download get_status command succeed
[12:05:32 079][HUB1-1][Inf]--get_status success
[12:05:32 079][HUB1-1][Inf]--verify sha1sum 0086eac8d57c2df6dc86b76929000822c02cc28a
[12:05:32 079][HUB1-1][Inf]--Send verify cmd succeed
[12:05:48 793]Read BulkStatus return 0: Continue:34, sleep 3s
[12:06:05 196]Read BulkStatus return 0: Continue:34, sleep 3s
[12:06:14 709][HUB1-1][Err]--failed:Verify Failed with sha1sum, origin sum "0086eac8d57c2df6dc86b76929000822c02cc28a" != gen sum "df9493880dadb8413486f6706b7133e8ff8a9435"
[12:06:14 725][HUB1-1][Err]--[0x30405004]UBOOT/Partition system/Verify patition/Error result
[12:06:14 725][HUB1-1][Inf]--Close device handle 0x000007f4
[12:06:32 330][Global][War]--User click stop button
[12:06:32 330][Global][Inf]--Enable burning 0
[12:06:35 001][Global][War]--Close tool
[12:06:35 532][Global][Inf]--Burning thread HUB1-1 end run
[12:06:35 532][Global][Inf]--Burning thread HUB1-1 exit
[12:06:36 017][Global][War]--Controler exit
Originally posted by GEGELAM View PostI am interesting to install Android TV on my MXQ PRO+ which is a s905x running android 7.1.2.
Any ideas ?
thanks a lot
regards
thanks for your quit Answer.
The power cord was connected. and the flash of the original Android image works fine, finishs with success and the box reboots fine after.
One of the difference I notice , is the fact that usb burner does'nt display key(overwrite) information with S905X_ATV_V2.7.img image.
GĂ©rard
There are currently 2784 users online. 1 members and 2783 guests.
