{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
    (Rom} S905X AndroidTV 7.1.2 V2.7
    V2.7
    -rebuilt to fix some issues
    -Playmusic updates and goes to regular app thats a google issue( Dont update if u want to keep it a ATV app)
    -Youtube App Has iSSUES with s905 (x)(w)(d) processors... known issue Use This app Instead https://smartyoutubetv.github.io/
    -first boot can be sluggish due to all the scripts and all installing but will be good after first boot
    -Look wise i have changed some things as well ...
    -fixed the screen saver issue it now shows never... your welcome
    You tell me how this firmware performs ... trying to fix most issues before heading into atvxperience firmware plus this will hold you guys off while we prepare the new firmware.... remember try to donate if you can ... we use donations to buy new boxes to make more incredible firmware for all you guys thanks again
    to do:
    -to get voice control working
    -optimize for 1gb devices
    This firmware will be the based of the S905X ATVxperience .... coming soon but enjoy this updated version as it is the final one before ATVxperience release
    Issues?
    -You let me know ????
    -Youtube does have alot of lag freezes etc... but its the app so i have installed old version dont update it .. if you did update uninstall updates and put do not auto update in play store
    Will work for the majority of s905x Boxes but not all
    Link: http://www.mediafire.com/file/4aja1p...X_ATV_V2.7.img
    I know You been Waiting For this and hope it works for you
    Ir remote is loaded with tx5 pro remote you can easily change it to whatever you want ....
    Donate:
    https://www.paypal.com/cgi-bin/websc...=HVFF8JVWX3NL8
    I got a tv box with android 6. Must be first installed android 7 or i can install your rom anyway? Thanks
      my rom is a full image so use amlogic burning tool to burn it , most boxes requires a usb male to usb male to flash
        Wow!!! I am impressed.
        Downloaded your ROM and installed it onto my 2 year old X9 (Mini M8S 2 clone) Amlogic S905x, using the USB burning tool version 2.12. Took 4 minutes 38 seconds to install, longest time it has ever taken to install a Rom. Just tested YouTube at 4k, and it played flawlessly, even 60 fps and NO dropped frames. There was an update for YouTube, and for testing purposes, I updated it. What a mistake, would not play anything without hanging. Uninstalled the update and playing again.. YouTube needs to get their act together.
        Will do more testing and report. Will be testing Kodi to see if it passes through HD audio........
        Edit: Further testing of 4k YouTube at 60 fps, got a lot of dropped frames, but NONE at 30 fps.
        Great job.....
        Edit : Netflix version 4.7.0 works with the remote (no need for a mouse), albeit in 480p, but that is a known issue on these boxes. The stock remote works out of the box, which is very good. The Airscreen app did not work, uninstalled it. Live Channels works very well, but only in stereo, not Dolby. Emby works great and the live TV streams play in Dolby Digital.
        Also, using a remote with dongle and voice, voice does NOT work.
        More testing to do......... But looking very good.
        Edit: Tested SPMC, but could only get stereo from my BlueRay rips with HD audio. Did not test any videos with just Dolby or DTS.
        • ricky divjakovski
          ricky divjakovski commented
          Editing a comment
          Im guessing he used V4.0.0 of my custom built AMLogic tools so the sparse image is much bigger then needed, if he does continue to support this rom using my tool his next version will be much smaller.
          to be exact his firmware should be just over 2gb(probably 2.12gb)
        Thanks ... and hd audio does work with spmc 17 I'm using it as I type ...i tried my best with this rom hope it meets everyones requirements
          Will this rom has wifi AP6330 support? (I have Nexbox A95X 2/16gb version, as I remember it has this wifi chip.)
            yes i believe it should work
              to get hd audio you have to enable output as raw and also passthrough as raw .... and dont forget to android settings and change it to hdmi not pcm .....i have this set up and it works
                Yes, I have done all those settings..... It is probably my box. Even VLC only outputted multi channel, on other devices, it will output HD audio......
                Still quite a feat, porting Nougat onto my older box.
                  I don't have a usb to usb-cable, but its possible to use a sd card to flash it like other roms, right?
                    yes its possible
                      yes its possible
                      Perfect, will try it tonight. Thank's for your work!
                        Great, i will try this tonight!!!
                        I now got the TX7 original 7.1.2 firmware installed, that works great but i have the feeling that it is not optimized because here and there i got some slow performances.
                        I will report back how it runs
                          The first boot takes awhile to optimize ... try to reboot ...
                            Unfortunately my remote doesn't work, how can i fix it? And now, how can i install libreelec/coreelec in a sd card? I've tried the toothpick method for the reset button but now it goes straight to android tv. there is a way to reboot in recovery mode from android tv?
