{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
Ok, I've used the right remote.conf and now the remote works, but there's a big issue. I can't turn on the tv box with the remote, the only way is unplug/plug in the power cord. Any suggestion?
Edit:
I've founded a workaround. If I set sleep mode on android instead of shut down it works but from coreelec the only way is to reboot first to android and use the power button to go directly in sleep mode.
Let me know if someone else got the same issue when you shutting down completely.Last edited by AlleV8; 01 August 2018, 16:08.
I've installed this on my x96 2/16 and it's working good, but Morpheus TV refuse to work. The app quits after a second or so. Any idea why? Other apps are wprking, and morpheus was working on the TX7 rom so seems to be some kind of compability issue with this rom.Last edited by antonh; 01 August 2018, 19:16.
Originally posted by AlleV8 View PostI did with terminal emulator using the command "reboot update" and it worked. Now i'll try to figure it out for the remote.
Anyway, sometimes certain app stop working even before they started and the screen goes back at the home. Maybe because my device has only 1 gb of ram?
There are currently 1881 users online. 0 members and 1881 guests.
