it's a 905x. they selling this box for a s905w but in fact is a s905x.
{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
Originally posted by bodrick View PostHi!
AFR does not work properly (Level 1.2). It does not switch the screen frequency back in many applications.
Could you include in the firmware this patch (updates_afrd.zip for twrp install)+ script (for activation afr) for the normal operation of the AFR.
Script code for activation afr:
#!/system/bin/sh
/system/xbin/afrd -D -p /mnt/var/run/afrd.pid /system/etc/afrd.ini
It works fine on the TX7 original firmware.
Guest
minixfreak - could you please also return the option to "Never" start the screensaver? It was in the original TX7 firmware and in your early (1.x) builds - but in 2.0 the max delay for screensaver is 2 hrs. Unfortunately, it turns on even when the movie is played in VLC... Thank you!
Great news .... I have been in contact with ATVxperience Team and this rom will be used as a base for them ... thanks everyone who supported this rom but the atvxperience team will do a better job at this point .... im very excited i have someome to help me make this firmware amazing instead of being solo on it
Originally posted by AlleV8 View Postcan you explain exactly how to apply this patch manually after a fresh installation of this rom?
Thanks.Originally posted by pawnthep View Post
How can I manually run the script after flash zip file in twrp?
First of all, disable the full system AFR (Level 1, 2 off). Also in players that have their own built-in AFR, for example SPMC. Allow the screen to force 1080/50 (this step is not necessarynot necessarily, but convenient for most video content that shows in 25/50Hz)
1. Install the patch with twrp
2. Add script in any convenient way (for example, using the Amlogic TV Box tool to the folder init.d)
3. Restarting box.Last edited by bodrick; 18 August 2018, 10:28.
Originally posted by minixfreak View PostGreat news .... I have been in contact with ATVxperience Team and this rom will be used as a base for them ... thanks everyone who supported this rom but the atvxperience team will do a better job at this point .... im very excited i have someome to help me make this firmware amazing instead of being solo on it
I'll start working asap
There are currently 971 users online. 0 members and 971 guests.
