{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
Originally posted by elektro86 View PostBad link
v2.0 http://freaktab.org/fea71a1334b304d9
Hi, tried to flash my Docooler M9S Pro 4k (3G/32GB) with the v2.0 version of the ROM but as soon as it started updating the firmware the box turned off completely and I cant start it anymore. There is no lights at all. Looks like there is no power. Do you thing the box is completely dead? Any suggestions how to fix it ?
Originally posted by prangoff View PostHi, tried to flash my Docooler M9S Pro 4k (3G/32GB) with the v2.0 version of the ROM but as soon as it started updating the firmware the box turned off completely and I cant start it anymore. There is no lights at all. Looks like there is no power. Do you thing the box is completely dead? Any suggestions how to fix it ?
tested version 1.2. There are wishes: you need to lower the version of Youtube from 2.03.06 to 2.02.14 (fix the hang of the image). It is necessary to correct: in the live channel the image does not stretch to the full screen, there is a black bar on the right and a black bar at the bottom. Sorry for my bad english. Thanks for the work, I expect corrections in the new version, I plan to use this firmware permanently.
I have made a update for this rom again ... fixes YouTube because I downgraded it ... also fixed twrp errors ... it's v2.1 .... the only thing we can't fix is autoframerate ... I used meecool m8s pro+ framework which eliminates some issues and makes this rom amazing besides the fact that it does not have auto framerate(HDMI self adaption)otherwise firmware is amazing and will be the final firmware I make unless meecool or anyone else has a fix to restore autoframerate(HDMI self adaption )
Hi minixfreak ,
I have one Mecool M8S PRO + and run ROM Guest the last build. Auto Frame Rate is run fine with Amlogic Android Tool app in SPMC and MX Player, but not run Kodi 17 and 18 i believe not amcodec in this apps.
Regards
Guest
Originally posted by minixfreak View PostI have made a update for this rom again ...
- Leanback Keyboard is unusable on my box (Zoomtak) because the OK button on the RF remote mouse doesn't work with it - it simply does nothing so it's not possible to select a character/key. Replacing the keyboard with LeanKey solved the problem for me.
- The option to use power button to put device to sleep is gone... And "shutdown" option is unreliable - it only works one time out of 3...
- The option to disable superuser is gone - is there a reason for this?
Everything else looks and works great, and it seems to be more responsive than version 1.0 I had installed before. Thanks again for your hard work!
Many thanks to minixfreak! This ROM seems to run very well so far. Here's a remote.conf I created for my 2G/16G X96 box. I tried a bunch of them from other ROMs but none worked so I created one myself. As always, it goes in /system/etc.Attached Files
Originally posted by IPTVKid View PostHello, just to be clear, I have X96 Mini using ATVX ROM and works great, my friend has the X96 but not mini, can he use this ROM or does his will only work with Factory ROM? No chance for improvement? Thanks in advance................
There are currently 3192 users online. 1 members and 3191 guests.
