{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
    Originally posted by bergerov View Post
    Hello, there is some option that Android will be (not Android TV)?
    If you want a regular Android (not a leanback TV interface), why do you need this ROM at all? Just use the original TX7 firmware this one was modded from.
      My mistake :-( I was looking bad
        Androidtv better layout and all it's preference ... if u don't want to use my Rom then don't but I made it because leanback tv is better in my eyes
          Just did a major update hope you enjoy everyone
            Thanks for the update. It runs smooth and fast. ​​​
            Auto framerate level2 works well with SPMC. Live Channel and Youtube (built-in version) also work. This is amazing!!
            BTW.
            I'm just wondering if I can change display framerate manually with shell commands, eg. from 60hz to 50hz?
              BTW.
              I don't know but you can try
                Can anyone verify that the Xfinity stream app doesn't Force Close still?
                  I turn off the console from the console. It turns off, but I can not turn on ((
                  Changing the remote config does not help
                    What device do u have
                      Made a video of your port............ Excellent work. One thing that is missing, the "Voice" function does not work. Everything else works like a charm.
                      Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                        https://www.youtube.com/watch?v=8pqX...ature=youtu.be
                        Appreciate it
                          x96, in other assemblies
                            Уважаемый minixfreak
                            много пользователей имеют приставки с 1gb памяти и почти у всех проблема
                            вот если бы вы создали прошивку одоптированую конкретно под 1+8gb память то вам было бы признательно куча народу.
                            я ставил почти все ваши ромы но корректно они работают только на платах с 2+8 gb а на 1+8gb всегда проблемы полные зависания и вылеты из приложений. лично у меня
                            mini m8s 2 все работает корректно прошивка от nexbox a95 (s905x) на всех других прошивках есть проблемы.
                              Miracast, ATV Remote service, Voice search, AOSP Settings crash or just do not work
                                Do u have 1gb device or 2gb
