{ROM} Universal S905X AndroidTV 7.1 (BIG UPDATE) V2.3 FINAL
    Did u restart after erasing ? Then try
      yes yes I did
        tested perfect player and works no problem .... reset your device and try again
          i used the usb to usb cable to flash firmware and everything is working fine if your using sd card to flash it maybe thats your problem reset it and try again
            also i use force erase and not normal mode when burning the firmware so it clears everything
              Originally posted by wimmetje View Post
              Great, i will try this tonight!!!
              I now got the TX7 original 7.1.2 firmware installed, that works great but i have the feeling that it is not optimized because here and there i got some slow performances.
              I will report back how it runs
              I tried it out this morning, flashed it with "force erase all" (just to be sure) and it booted just fine towards the setup screen with no hang ups or reboots.
              I didn't have time left to really tested it because i needed to go to work, but it looks that it is working on my device and also the remote is fully functional!
              I gonna do a proper test tonight and see how everything is working!
              MY device:
              TX3 PRO 1GB
              Edit: I heard that some devices had problems with going from 6.1 towards 7.1 without properly changing there bootloader toward a other (newer) version.
              I had the same problem going from my stock 6.1 towards 7.1 flashed a lot of different roms but wouldn't boot,
              But finally i came to forum (russian one) where someone told that you need to update to a other 6.1 rom (russian), and after that i could flash the TX7 7.1.2 (stock) firmware that booted just fine after that!
              I need to look it up tonight which firmware (6.1) it was, i have it stored on my computer.
                Hello. I have installed the firmware on the x96 2GB 6330 chip. The firmware is good, but here is some problems:
                - The Android TV remote does not work on the phone
                - The OK button on the remote control makes rewind
                - Wifi does not work on my chip.
                - Can’t turn on device from remote controller.
                - Device goes to sleep by any shutdown options (sleep, shutdown, reboot).
                - Splash screen does not work. When it's showed up, the device goes to sleep.
                  im working on a newer more optimized build ..... when ever i finish ill post ..... might need testers before posting let me know
                    its not setup for every single box .... but most s905x are supported , im not going to port it over to that device when i dont have it
                      Great! I could be a tester, let me know.
                        I'm ready to test.
                          sorry guys i ran out of time for now to try to improve the rom , i did do some improvements but failed to boot so this will be in the back seat as i have to work ..... hopefully another dev can come improve my rom i would appreciate the help
                            T95N S905X P212 1gb/8gb box here. Won't flash. Gives me the error:
                            [17:58:59 257][HUB3-3][Inf]-------------Download _aml_dtb.PARTITION-----------
                            [17:58:59 258][HUB3-3][Inf]--0-7-0-16
                            [17:58:59 258][HUB3-3][Inf]--download store _aml_dtb normal 88064
                            [17:58:59 259][HUB3-3][Inf]--Send download command success
                            [17:58:59 432][HUB3-3][Err]--failed:
                            [17:58:59 438][HUB3-3][Err]--[0x30402004]UBOOT/Partition _aml_dtb/Initialize partition/Error result
                              some t95n come with ddr4 memory and different uboot ....thats probably your problem so wont work
                                хочу установить эту прошивку на vonyar mini m8s+
                                но не уверен что будет работать???
