I don’t have any HDMI settings in my sound menu that’s the weird thing. Surround is on auto! When I connect to my Bluetooth speaker it works but with optical or hdmi cable 0.0 sound.
X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by satstarter View PostThat's strange i have in droid settings audio output hdmi and spdif and there i have hdmi on.....?
i must say however i have the atv firmware on my box
but i think you must also have these setting on the original firmware
- PCM
- SPDIF (which I tried with optical cable but again no sound)
- Auto
- Manual
So no HDMI option. I received the box yesterday with stock android 9.0
Originally posted by omaramiromo View PostOk.. i manage to revive my device.. but using the rom that flashed that brick my device... i am flashed succesfully using burning tool.. but the trick is.. i short circuit the board.. i open the box and get access to hdmi component..
Here the step:
1 - open burning tool, load the img firmware that u use and cause the stuck at boot logo. As usual, click the start button after load the img.
2 - connect ur box using usb 3.0. Windows will show the device is not connect/ detect..
3- here come the trick.. take a small flat screw driver, go to hdmi port.. connect the pin using screwdriver( just touch and lift), the led will off and on.. repeat the process untill burning tool detect your device. The location of pin is the 2 and 3 from above ( as per picture)
4. Now i manage to boot up the box.. but the problem is now i cannot enter the recovery..
Any idea which pins I need to short at the X96 max? I bricked my device. It arrived with no sound so I trough a custom rom, worked perfect but now it got a boot loop and the reset button doesn’t work with this custom rom.
Originally posted by kevinho040 View Post
Any idea which pins I need to short at the X96 max? I bricked my device. It arrived with no sound so I trough a custom rom, worked perfect but now it got a boot loop and the reset button doesn’t work with this custom rom.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by RiCkLaR_atvX View Post
No, the 9.0 version can NOT be installed by OTA update or zip. Will need to flash 9 Pie firmware with USB Burning Tool. This way any changes in bootloader and uboot which are specifically for Pie update are properly installed to your device.
Originally posted by bishopx26 View Postcan u tell me please the full steps how to flash it ?
I try these today but nothing happened... :-(
what’s the exact way you did it to fix your box?
Originally posted by Nebojsa View PostMy HDMI output not working, no signal on TV, but box working normally when connected to av port.
Anyone have this problem?
sem imagem pela saída hdmi, só tenho imagem se for ligada pela porta AV.
Alguém sabe como resolver este problema?
Box X96 Max 4/64
I have the same problem!
no picture by hdmi output, I only have picture if it is connected by AV port.
Does anyone know how to solve this problem?
Hi, I flashed a ROM by Xannytech on the 4GB/32GB X96 Max and for whatever reason the USB 2.0 port doesn't seem to work right. The port powers things on but no data works and plugging in any USB peripherals work. I did have to use rom mask mode because a previous rom I flashed before that made the reset button in the av hole not work. Other ports are fine though
There are currently 1987 users online. 0 members and 1987 guests.
