X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by box_man View PostHi, i'm newer here. Bought recently a X96Max but is somethig wrong with the ethernet connection. With ethernet cable the internet connection is very slow, not even gets to 1mps, it only works with the wi-fi. Does someone having the same problem?
I have X96 max 4/64 and it's bricked.
There is no light when apply power (power adapter is good).
When attached to pc with male/male cable have SPDIF light and pc register "unknown device".
USB burning tool don't register device, have version 2.1.7.0.
Tried every combination to make usb burning tool to recognize device but no success,
shorting pins on hdmi port, pins on the back from Russian site, applying power and usb, reset button, no luck.
Burn card maker also not working.
Anything else I can try, I have no idea anymore...
Is it hardware bricked? It's hot when plugged in.
Is it hardware bricked? It's hot when plugged in.Last edited by glaven; 29 March 2019, 18:55.
During USB tool installation the drivers also get installed as something called world cup device.
You can even try a different version usb tool such as 2.6.8 etc. Or you may have a faulty cable. These are other ideas for you try.
Best of Luck.
This is not the first box I have connected to this pc, so we can exclude those things like cables, drivers etc.
I have RS232 adapter and connected to GND RX TX of the box but don't get any readings (other box is connected fine).
Anyone knows where are those pins, maybe I have connected it wrong?
Originally posted by Nebojsa View PostThis is not the first box I have connected to this pc, so we can exclude those things like cables, drivers etc.
Originally posted by Nebojsa View PostTried every combination to make usb burning tool to recognize device but no success,
I'm asking about GND RX and TX pins for connecting RS232/UART adapter to PC
and see in Putty what happening when apply power.
There should be some readings even if there is no light on the box and it looks like completely dead,
but there is nothing in Putty.
Am I right, first is GND, second TX and third RX pin?
There are currently 2297 users online. 1 members and 2296 guests.
