X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
My x96max 4/32 after a time of inactivity can not be started from ir remote or CEC remote. The single way to turn on is unplug/plug power . Same problem on original and moded ATV Rom .
Tried so far :
disable on original rom screen saver and no inactivity period , on moded rom i don t find the option
CEC disable One key play/One key powerLast edited by sebip; 21 February 2019, 08:50.
Originally posted by sebip View PostMy x96max 4/32 after a time of inactivity can not be started from ir remote or CEC remote. The single way to turn on is unplug/plug power . Same problem on original and moded ATV Rom .
Tried so far :
Originally posted by uscool View Post
Another thing no point setting it so it goes into standby/sleep with Stock ROM it wakes up automatically and on Custom ROM it goes to sleep but if try to press power to get it on agian nothing happens this is once the box been on standby for quite a while
no solution other then set the power to shutdown box you can power it back on by pressing power on remote box boots up fast so can live with it , maybe they will make update to fix i dont know
system/etc/permissions/android.hardware.hdmi.cec.xml so put 2 line in build.prop
ro.hdmi.device_type=4
persist.sys.hdmi.keep_awake=true
Restart your device
Problem solved. Now you can awake from CEC
SPDIF problem!!
1.Bought x96max 2/16
2.Sound via optical(spdif) worked 2 days,than stoped.HDMI and AV sound works well
3.Got 60 % refund from store..
4.Bought another box from another seller. this time 4/32 box
5.Same thing..SPDIF worked 2..3 days.After that NO SOUND from SPDIF(red light from spdif output is visible) ..Sound via hdmi and Av works fine.
Tryed custom roms.. same thing.
Any solutions????.
I was having huge issues with the recognition of external USB HDD's, the box would only see 2 whatever I tried. I seem to have solved that problem by using an Orico USB 3 hub, my previous one was generic. Working flawlessly now, but only time will tell. Arrived this morning and I am delighted.
Originally posted by Venusflytrap View PostUpdate (reviving my bricked X96 Max): I figured out the fix. I installed on a blank formatted micro SD card the extracted files from this zip file (containing 4 items for a TWRP recovery image and a boot up menu for the X96 Max):
https://drive.google.com/file/d/1nJY...w?usp=drivesdk
and then I also copied onto the same micro SD card the OTA zip file from jiangsai0703 in post 53. (I kept it zipped, I didn't extract it). This is the OTA zip:
https://drive.google.com/file/d/1ULW...ew?usp=sharing
I then put the micro sd card into the X96. I then plugged in the power while pushing the AV recessed reset button for a minute. The TWRP then loaded, and then I used the install from zip file option to which I pointed it to the ota zip file located on the micro SD card. I swiped the slider to the right to flash the data. It installed perfectly. Rebooted and the X96 came back to life. Thank goodness.
My original question below:
Help! I have a X96 Max 4/64. It was working fine until I installed SuperSU (normal install). After it restarted, it seems to be bricked and I'm stuck at the X96 Max logo. I then did the toothpick in the AV hole trick to get to the Android menu. I then tried a wipe/factory reset. No luck, upon restart I'm still stuck at the boot screen. Please if someone would be so kind as to help guide me what I can do to unbrick it. Thanks.
I am in the same sad situationCan I do it with USB Flash disk as well?
Thank You!
Sipi89; I don't know if doing the flash using a USB stick would work as I didn't use that method. You can always try and see. Just make sure that your USB stick or microSD card is formatted using FAT32. Also, as the X96 Max has a couple of USB ports, if one doesn't recognize your USB stick when you boot up, then try the other USB port. )I say this because one is a USB 3 port the other is USB 2 and one of those ports may be setup to do USB boot ups.
Originally posted by Venusflytrap View PostSipi89; I don't know if doing the flash using a USB stick would work as I didn't use that method. You can always try and see. Just make sure that your USB stick or microSD card is formatted using FAT32. Also, as the X96 Max has a couple of USB ports, if one doesn't recognize your USB stick when you boot up, then try the other USB port. )I say this because one is a USB 3 port the other is USB 2 and one of those ports may be setup to do USB boot ups.
There are currently 3447 users online. 0 members and 3447 guests.
