X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
    Originally posted by metabesk View Post
    The box isnt electrically isolated this has nothing to do with bricked box.
    Ok, nvm then. I use couple of these boxes without hdmi surge without problem...
      Originally posted by zoelechat View Post
      You must be charged negatively
      Charged? There is no battery.
        You should ask yourself the right questions. I easily believe these cheap things - where HDMI frying is a long story - are not correctly or not enough protected but... 2 in a row! There must be another of your devices "pissing in ground" beyond reasonable limits.
        Nevermind
          Nevermind
          Eheheh i didnt read your post correctly. Sorry!
            You are lucky then,or i am totally unlucky. But there is tons of users with the same fate!
              Hello my remote control not working. Help?
              Any code to set to the box to work?
              Led red is working but not control any e android box
              Enviado do meu LYA-L29 atrav?s do Tapatalk
                Hey ppl!
                Does something changed in 20190315 x96max 2gb update ?
                I am still on 20181123...
                  Hey ppl!
                  Just a keyboard fix
                    Originally posted by abhifx View Post
                    Just a keyboard fix
                    They still haven't fix low quality audio output via headphone jack when hdmi is in..?
                      how to speed up boot screen ?
                      also , box send to standby, after power up again .. long boot screen in starting
                        Does anyone knows what audio chip this unit use?
                        From my subject ear it is not audiophile level...
                        It sounds like low gain mono (aux out -- speaker).
                        It seems I can not disable hdmi audio passthrough on this box...
                        Some intutition tells me that's probably some software issue..?
                        EDIT:
                        After prolonged time testing aux output on this unit, I presume it is dual mono or low quality stereo signal on default (deezer, webbrowser, media player). On kodi I hear some difference, so I think it is both hardware (low quality chip?) and software (encoders, decoders?) issue...
                        Does anyone tried Viper4android on x96max box?
                          Originally posted by zap View Post
                          The correct pins to short are here (the link leads to russian forum 4pda, just open the spoiler, the picture is inside):
                          When you short them, the CPU will not detect the eMMC circuit during startup, thus will start some internal copy of the bootloader which will happily connect with USB Burn Tool.
                          So, short the pins on picture and recycle box power... keep the pins short until UBT detects the device.
                          This will unbrick any device even if you fill the whole eMMC flash with garbage...
                          Initially UBT detected the H96 Max X2 box when shorted the HDMI box, but it got failed at 3% during flashing and when i pushed the refresh button on UBT and clicked the start, I got 3rd error "0x00101004". From there the HDMI pin short method not working. Can someone help how to make the device get detected in UBT tool. Error pic attached.
Name:	H96 Max X2 UBT Error.png
                            Originally posted by omaramiromo View Post
                            Glad to hear that man.. actually i read somewhere that need to short circuit using nand flash pin component.. but i cannot found that pin on our box board.. then i try the hdmi port and boom.. it worked.. hope this method can help other people who brick their box... enjoy
                            Hi can i know if this method work for h96 max x2? Mine is totally dead.
                              This is not thread for that box - try to ask your question on https://forum.freaktab.com/forum/tv-...-lan-bt/page37
                                Hey ppl, there is Android 9.0 (Pie) for x96 max. It came couple of days ago.
                                Does anyone try it?
