X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by uscool View Post
Hi after using the X96 max the 2gb model for week, with stock and custom ATV ROM, the Stock ROM doesnt work with latest YouTube ATV app and gives green scrambled screen on Live streams but on custom ATV the latest YouTube ATV works but still get the green issue, but can use Smart YouTube instead which works on both fully
Another thing no point setting it so it goes into standby/sleep with Stock ROM it wakes up automatically and on Custom ROM it goes to sleep but if try to press power to get it on agian nothing happens this is once the box been on standby for quite a while
Although the WIFI speed is very good it randomly can just vanish this can in 1hr or few hours and box needs restarting to get it working again happens on both stock and custom rom
the speed of the box is very good and it can play pretty much any video file very well
Hello. i have x96 max 4/32G Does not work. I tried to update it WITH USB_Burning_Tool but Each time it stops at 7% With several roms
I tried to update it with SDcard and not work
https://ibb.co/HFYY7fw
Originally posted by fethi82 View PostHello. i have x96 max 4/32G Does not work. I tried to update it WITH USB_Burning_Tool but Each time it stops at 7% With several roms
yes i used to update my box but stoped at 7%
(Subsequent stock updates seem to have solved the issue as I have had no problems since.)
Originally posted by glaven View Post
My X96 Max4/32 wouldn't boot up and I also got stuck on 7% when I tried to flash another Rom. I eventually solved the problem by booting TWRP from an SD card (see post #108 by Venusflytrap) and clearing cache and dalvik cache.
omaramiromo BiBaBuTzE
I think I have the exact same situation as you had that I flashed new firmware using OTA.
I tried your way to short circuit the 2-3 pin of HDMI, the box rebooted and the burning tool can detect it, but right after 3-4 seconds, it is disconnected again like before.
I shorted so many times even with 10 seconds, but still no luck. Also tried to short the "correct" points from Russian forum, but nothing happened.
Originally posted by BiBaBuTzE View Post
Hello alwayssunny, I think my Problem was, I have connect the Box in Burning Tool before I push the Startbutton, but you must push the Startbutton and then connect the Box. This was my fault. Try this. First Startbutton, after this connect the Box to USB port.
The trick is to uncheck the erase bootloader and flash the same firmware!
I did a lot of time with erase bootloader checked by default and will alway fail!
Originally posted by uscool View PostHi after using the X96 max the 2gb model for week, with stock and custom ATV ROM, the Stock ROM doesnt work with latest YouTube ATV app and gives green scrambled screen on Live streams but on custom ATV the latest YouTube ATV works but still get the green issue, but can use Smart YouTube instead which works on both fully
There are currently 1868 users online. 2 members and 1866 guests.
