X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by omaramiromo View Post
What do you mean by not recognize?? My box 4/64 have no problem at all using ethernet port since I purchase it 2 month ago
I read that I am not alone - may be there are different HW versions around ?
Originally posted by laola View Post
As I booted the box the very first time, Ethernat was detected and IP adress has been assigned. However, the performance was poor (i.e. I had internet access but it failed to connect to my home server. Then I tried WLAN and everthing worked fine. But since then, I never had Ethernet anymore - even not after a full reset...
I have see other Ethernet issues reported, like low speed or not able to performcertain tasks, but nowhere that they couldn't connect at all
I received my X96 Max this morning and Ethernet seems to work perfectly as does WiFi. However, FTMC will not work with this device and Kodi reports "detected problems with app native libraries" which I believe is an Android problem. Only 2 of my 4 external drives are recognised. These drives do work as they should though.
I tried alternative firmware but it would not install from SD card or from USB Burning Tool, I received the same error as I did from my H96 in fact.
In conclusion I will keep the box this time as most of it works. I must await a firmware update that will allow more USB external mounts. I recall this mount problem in my Minix X8H Plus box but it was corrected in an update.
EDIT: SPMC doesn't work either while Krypton throws up an error "detected problems with app native libraries" on start but does play my external media.
I wonder who I would report errors to in this case? The box is unbranded.Last edited by Charlie_Boy; 21 January 2019, 18:25.
Originally posted by Jancales View PostJust thinking loud. As it is obvious that all S905X2 boxes have issues somehow, could it be the Android 8 is the real reason for all these problems?
Originally posted by Charlie_Boy View Post
I think all of them have issues as you say but who do we report errors to? The sellers know less than us about it in most cases.
The only thing you can do is waiting until Amlogic or Android fixes something.
For the time being I don't touch any of those S905X2 boxes, however I think they are promising once things get sorted, we only don't know how long it will take.
Remember the S912 boxes also had loads of issues first 6 months after release.
You can't report to anyone as i think all these boxes, except Beelink and Mecool, are manufactured by a myriad of Chinese factories.
Originally posted by Venusflytrap View PostThats the problem with these resellers (not helpful) while conveniently the manufacturers escape from being held accountable as they are mostly never publicized as to who they are.
Originally posted by Venusflytrap View PostNot cool that they ship these things out before doing the beta testing first. Unfortunately, the consumers get stuck with these not-ready-for-primetime boxes.
Originally posted by glaven View PostOn a positive note, since receiving my X96 MAX in late December there have been 3 updates. So at least it looks like the manufacturer is trying to sort things out. Compared to my execrable Tanix TX28 (still in beta since last July and gathering dust in the loft), I'm pleasantly surprised.
Originally posted by Venusflytrap View PostDo you notice any changes or improvements with this "system optimization update"?
There are currently 1627 users online. 0 members and 1627 guests.
