X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by BiBaBuTzE View Post
At me, the same too. No Chance to get to recovery
download the 7zip file in message 90. It is used to format the microsd card. The formatting program asks for a formatting protocol file. From message 90 download the X96 uboot.bin. Then use the formatting program and select that uboot.bin and then format the microsd card. Then copy those files I used over again. Maybe it'll work then.
(normally Windows 10 will format a microSD card OK but maybe when you did, it didn't work right)Last edited by Venusflytrap; 11 January 2019, 21:16.
Ok.. i manage to revive my device.. but using the rom that flashed that brick my device... i am flashed succesfully using burning tool.. but the trick is.. i short circuit the board.. i open the box and get access to hdmi component..
Here the step:
1 - open burning tool, load the img firmware that u use and cause the stuck at boot logo. As usual, click the start button after load the img.
2 - connect ur box using usb 3.0. Windows will show the device is not connect/ detect..
3- here come the trick.. take a small flat screw driver, go to hdmi port.. connect the pin using screwdriver( just touch and lift), the led will off and on.. repeat the process untill burning tool detect your device. The location of pin is the 2 and 3 from above ( as per picture)
4. Now i manage to boot up the box.. but the problem is now i cannot enter the recovery..
Originally posted by omaramiromo View PostOk.. i manage to revive my device.. but using the rom that flashed that brick my device... i am flashed succesfully using burning tool.. but the trick is.. i short circuit the board.. i open the box and get access to hdmi component..
Here the step:
Here the step:
Did you have any picture from the hdmi Port and the Pins to shortcut?
I will give it a try and report u. Thanks a lot.
Also i manage to enter the recovery using the AV reset buton + power cord after flash XTMod Rom.. I hope u can revive your box back.. Good luck..
Here the step:
That Was the right advice. The trick to shortcut the HDMI Port with the Burnintool. Wowoowwo
Thanks a lot and have a nice day man.
IT LIVES!!!!!!
IT LIVES!!!!!!
Do you use the same rom or different rom?? I think is does not matter which rom we use.. just need to short circuit it.. thats all
Glad to hear that man.. actually i read somewhere that need to short circuit using nand flash pin component.. but i cannot found that pin on our box board.. then i try the hdmi port and boom.. it worked.. hope this method can help other people who brick their box... enjoy
When you short them, the CPU will not detect the eMMC circuit during startup, thus will start some internal copy of the bootloader which will happily connect with USB Burn Tool.
So, short the pins on picture and recycle box power... keep the pins short until UBT detects the device.
This will unbrick any device even if you fill the whole eMMC flash with garbage...
There are currently 2007 users online. 1 members and 2006 guests.
