X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Originally posted by glaven View PostShow me the version and link to the apk that you have in mind and I'll happily test it for you.
Please test mouse movement and clicks also playing videos in HD
Thank you
Originally posted by glaven View PostOK I have installed your version. My air mouse works better than stock because the pause/play now works! Video quality is the same as the stock which I don't think is full HD. Is there a way to definitely check this while a video is playing? I've set the video quality to high in my profile.
try it with other connection did you have wifi probelm?
Originally posted by glaven View PostJust checked on my Huawei M5 and it shows HD next to the episode list. When I checked the same on the X96 there is no HD symbol so it looks like a DRM problem.
Originally posted by Charlie_Boy View Post
I have just tried the XTMOD-ATV X96 Max on my X96 Max 4/64 and it works very well. Youtube was 720p HD but I did not try Neflix, I do not have an account.
Originally posted by uscool View Post
I have tried XTMOD-ATV X96 Max on the 2gb /16gb model , YouTube ATV i get 4K but if i watch live streams I get scrambled green screen with sound only but use Smart YouTube app which works, Also Although WIFI is very good and works fast randomly can happen after 1 hr or 6 hrs the WIFI will just vanish and box will go totally slow and need unpluging been testing with Ethernet cable and so far not had same issue, been told these issues only happen on the 2gb / 16gb model
That's interesting as I did not get the same errors, though I do routinely use Ethernet, but did try WiFi. It is odd that only your model seems affected. I liked the ROM but found it heavyweight for my needs. I do not use ATV, rarely use Youtube and never Netflix. My issue with the mounts remains though and only two HDD's were found. I am pinning my future hopes on a stock firmware update or a port of OpenElec or LibreElec for the X96 Max 4/64.
There are currently 1785 users online. 0 members and 1785 guests.
