X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
Why would more storage space be needed with acestream? I thought it was recommended to avoid letting it cache to disk.
Regarding the price, I know it might seem like a "small" mark-up to most people, however my issue with it is that not only am I unlikely going to be needing any of the storage space in the first place (if there was such a thing as a 4GB or 8GB storage model, I'd probably get that tbh as long as it had 2GB or more RAM), but the cost of one of these X96 Max devices is already approaching or at the same as my fall-back solution: a 2nd-hand Z3/Z3C (because it has an alternative/non-USB dependent charging/power option) & a MHL dongle to simply mirror its screen onto the TV.
@uscool thanks for the infoLast edited by Delicious Cake; 28 April 2019, 19:48.
Originally posted by Delicious Cake View PostWhy would more storage space be needed with acestream? I thought it was recommended to avoid letting it cache to disk.
two x96max 4/32 drop dead on me with no video, led panel works, says boot update the time to utc+3 but black screen on tv no video signals detected. Anyone got this problem or everyone's device working flawlessly, is it my bad luck or reseller sends me refurbished devices? Would you please advise because the device in terms of power was magnificient and problemless with xanny's atv v4 rom.
I tried Xannytech's new firmware to see if it would fix my issues with the SPDIF port, and to no avail. As I am not the only one with this issue, it's fairly obvious it's a hardware problem and these boxes are garbage tier. Not even 3-4 months old and broken. No point in sending back to gearbest as shipping to China is stupid expensive.
I would strongly suggest anyone thinking of buying this box to not.
Originally posted by Kuno View PostI tried Xannytech's new firmware to see if it would fix my issues with the SPDIF port, and to no avail. As I am not the only one with this issue, it's fairly obvious it's a hardware problem and these boxes are garbage tier. Not even 3-4 months old and broken. No point in sending back to gearbest as shipping to China is stupid expensive.
Originally posted by nikolaign View Post
What?! Its the first time I hear that tv box need esd protector dongle. Can you explain please? Is it because of the update?
Originally posted by metabesk View Post
No it is a hardware problem, these chinese cheap boxes doesnt have built in protection for hdmi surge, normally your tvs or monitor have. I think most of these boxes havent the protection but x96max for sure
If optical out is turned on and you still have no sound or you experience sound drops, this might help:
You have to pull the inside of the optic wire a little further out of the connector so that is goes deeper into the device/optical output connector. I think the distance between the light that transmits the signal and the wire that receives it is too big, because the light is too deep in the box.
I?m not sure if this is the reason for the problems many have, but this action solved the problems I had with the optical output.
There are currently 2302 users online. 1 members and 2301 guests.
