I seriously need some help !!!!
X96 MAX TV Box BLACK 4/64GB Amlogic S905X2, Android 8.1, Dual WiFi, Gig Lan,USB3.0, BT4.0
I own 2 of that box. One worked and am using it, other one was stuck on Boot Logo so flashed Poison ROM via SDCard method but remote ain't working as it should, so decided to flash Stock ROM only now am getting "can't install this package over newer build" message. After googling I saw that one must have a newer recovery either on device or inside ROM zip which I have no clue as to how to do. I cannot get PC to recognize my box so SDCard is only way to do it. Also with POison ROM on the device holding Reset A/V switch does absolutely nothing ziltch..
Originally posted by Venusflytrap View Post
I just tried it on mine for you. I have the same issue, it won't save the SPDIF setting once I exit the Droid Settings. Mind you I don't have a SPDIF setup. Perhaps the receiver that it's hooked up to has to be turned on and TOSLINK inserted in the box in order for it to activate on the X96 Max? Just a thought. Although I'm leaning towards it being a firmware bug.
It seems to be a generic issue with all S905X2 at this point. Tried the Beelink ROM but it has no optical port and the setting is not available in droid settings.
Can anyone else confirm if Optical setting 5.1 sound is working? Thanks.
Originally posted by Venusflytrap View PostUpdate (reviving my bricked X96 Max): I figured out the fix. I installed on a blank formatted micro SD card the extracted files from this zip file (containing 4 items for a TWRP recovery image and a boot up menu for the X96 Max):
https://drive.google.com/file/d/1nJY...w?usp=drivesdk
and then I also copied onto the same micro SD card the OTA zip file from jiangsai0703 in post 53. (I kept it zipped, I didn't extract it). This is the OTA zip:
https://drive.google.com/file/d/1ULW...ew?usp=sharing
I then put the micro sd card into the X96. I then plugged in the power while pushing the AV recessed reset button for a minute. The TWRP then loaded, and then I used the install from zip file option to which I pointed it to the ota zip file located on the micro SD card. I swiped the slider to the right to flash the data. It installed perfectly. Rebooted and the X96 came back to life. Thank goodness.
My original question below:
Help! I have a X96 Max 4/64. It was working fine until I installed SuperSU (normal install). After it restarted, it seems to be bricked and I'm stuck at the X96 Max logo. I then did the toothpick in the AV hole trick to get to the Android menu. I then tried a wipe/factory reset. No luck, upon restart I'm still stuck at the boot screen. Please if someone would be so kind as to help guide me what I can do to unbrick it. Thanks.
I had the exact problem with my X96 Max 2/16. But now it is even worse. I tried same method with same files you put links to. But when I tried to boot (after flashing in twrp) it is dead, not even boot logo. Now it is all black screen, no blue clock on x96max lcd, nothing, but tv recognize hdmi, but there is no picture. Tried to enter recovery, but that is also not possible. I will try pc method with different .img file. Anyone have some advice pls?
Solved it!
With many attempts shortening pins, finally bring my box back to life.
Done it with both burnSDcard and USBburn tool. First prepaired sd card, insert into box, then initialize USBburn method with correct pins shortening.
On this box (x96 max) pins that worked are HDMI pins, 2nd and 3rd when you look from right (hdmi port facing up).
Thank you all!
Originally posted by glaven View PostDoes anyone have a link to the stock recovery? I installed TWRP and the OTA update doesn't work.
Thanks in advance
Last update for 4/32 and 4/64 versions is 20181219 dated. If you have any of this versions (NOT 2/16) of x96max, you can update. Just search on google: X96max firmware update. First couple of links are legit.
Originally posted by nikolaign View Post
What model?
Last update for 4/32 and 4/64 versions is 20181219 dated. If you have any of this versions (NOT 2/16) of x96max, you can update. Just search on google: X96max firmware update. First couple of links are legit.Last edited by glaven; 07 March 2019, 12:46.
I have a 4/32 . The updater is trying to update to V311__20190223-1604. All I need is the stock recovery and then it will automatically update. Once I have the latter I will be able to swap between TWRP and the stock recovery each time there is an update.
https://www.mediafire.com/folder/5vk...X_20181219.zip
Or directly from.
Originally posted by Charlie_Boy View PostI installed the stock recovery and it still won't update and I tried the entire image, still no update.
EDIT back in business. The second method worked eventually.Last edited by glaven; 08 March 2019, 13:25.
Thanks for the links. Did you flash the img stock recovery file with TWRP? Unfortunately I used TWRP to flash one I found before you posted your links and now have have a boot loop. I can't flash a new ROM because the USB burning tool can't see my device. I think I will have to do a nand reset but so far the hdmi method and the two pin method on the russian forum haven't worked.
There are currently 2285 users online. 1 members and 2284 guests.
