- 10 bit h264/h265 video is not stable
- Type C port not working
- Screensaver not working. Sleep is buggy, and wakes without remote used
- DRM not available
- HDMI handshaking issues
- Amazon Prime Video crashing
- Netflix app not compatible, need to use old v4.12 app
- HDR not working
- Youtube freezing after 5 minutes
- Can't use SuperSU 2.81 then the device goes into a bootloop
- Wifi issues with 2.4Ghz
- Wifi disconnects by itself sometimes
- HDMI CEC not working
- 4K videos downscaled to 1080p in Kodi
- No deinterlacing support in Kodi
- Auto frame-rate and colorspace switching not available
- Can't play high bitrate flac audio files
- Can't add a default route when modifying the static ip for ethernet
- Can't write to external storage
- NTFS Write and Exfat support missing
- Can't install Nova or other launchers then they crash
- Can't connect 2TB or higher hard-drives mostly Seagate and other brands
- Lots of apps missing or not possible to install from the Play Store
I don't think new S905x2 devices have even half of these issues.
So lets hope Magicsee can fix everything or not.
