MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    Spot on guys .... The scores went up by 15k Click image for larger version
      New Firmware is out and they have made perfect video about how to upgrade!
      RK3399 tv box upgrade tool download link: https://bit.ly/2rVzlsr
      Magicsee N6 MAX firmware download link: https://bit.ly/2Tdj91l
      • trebor
        trebor commented
        Editing a comment
        Do they have a change log of this NEW firmware available ?
      Cheers mate!!
        Hi Jose
        Keep in mind;I'v also tried this one too!
        Problem is still continue
        And this problem is not related MXPlayer,if you use default Player(Media Center) same issue persist!
        Yesterday I'v also tried(thru GPlayStore) 3 different Player and one is VLC Player...
        So problem with Box HW or FW
        Bye++
          What are the fixes in this!!
          if anybody knows please let me know
          Cheers
            Hi ,
            why u not use a stock BT Mouse with Keyboard , i use the Logitech K330 , works great with Mouse
            on every TVBox ,
            greetings / gefattern
            Well,I'v wireless KB+Mouse but I do not like it even I do not use KB
            So,just I need a good Air/Fly Mouse only
            For example like X99 Air-mouse was good
              sidglide
              There is no any Heat problem with this box
              Its very cool
              For example X99 get it more heat!
              And I ignore it all Benchmark tests
                Today I'll try to new F/W
                Previous upgrading(for GooglePlay account issue) they tell us "SD Card Method" and given their Tool and instruction
                And I'v used this method without any issue and done the Flashing succesfully
                Wondering is this method still going on?
                Which is way better&easy for flashing!
                  My reply indicates that an OTA app is loaded on the box, at least that's is my take-away..
                  Also I understood no boot-card maker was needed.
                  I would think if the type C is inop, then the 3.0/ 2.0 or sd slot will get results. No?
                  Magicsee says:
                  Hi,Clark
                  Thanks very much for your support on Magicsee
                  whenever and whatever problem you have,you will get our support.
                  About the updates,
                  You have two ways to upgrade,
                  1.upgrade via Android tool on PC (If the device can not work, upgrade on PC can solve all problem)
                  we make a video about how to upgrade,you will fimd it is easy.
                  2. Upgrade via OTA
                  You can download the OTA version firmware onto a USB disk, run the Newotaupgrade APP.
                  IT can upgrade automatically
                  If your box can work,but have some little bug,this way can be easier.
                  - Any question, feel free to contact us.
                  Best Regards
                  Shenzhen Magicsee Technology Co.,Ltd
                  Tel: +86 755 26532142
                  ADD: No.242,Xixiang Road,Baoan District, Shenzhen city,China
                  website: www.magicsees.com
                  I say OTA, Baby! Even a caveman can do it.
                    Magicsee says:
                    Hi,Clark
                    About the updates,
                    2. Upgrade via OTA
                    Best Regards
                      Hey guys
                      Another joke
                      "Type-C Port" still does not work!!
                      I'v inserted my Type-C Port Adapter and tested some of USB drives but Box still doesnt recognize
                      what the hell man,they knew those stupid port issue and told me that they will release F/W for
                      Type-C Port issue
                      so WTF
                      Therefore I'v already watched YT flashing video and proceed all necessary steps and Successed
                      Now my FW already changed dated;20181217
                      But what about Type-C Port issue,so you cant use it!
                        antutu score with new fw 95429
                          For Flashing latest FW(20181217) watched their video-guide and do it easly+
                          I'v Type-C Port Adapter(but they advised "Type-C Cable" and directly connection between Box and PC
                          Mine method was Type-C Port Adapter+USB3.0 Cable(Male-Male end)
                          as same above their advised method and I'v already flashed
                          Mine PC Win7(64bit)
                          Installed Driver without any issue(but I got warning fm Win7 such as Drivers will not proper installed .....
                          but I ignore it! in fact installed very well(if you got this warning just ignore it!)
                          Clark
                          As your stated second method is way better(OTA Upgrade) but I dont know processing,such how to do that??
                          or is it possible to use with this Box?
                          Also SD Card method way better though
                          And why still Type-C port does not working f..........
                            Already sent eMail to MagicSEE Co. right now
                            Still "Type-C Port" doesn not work
                              And does any one has tested of their Type-C Port work with new FW???
                              mine is still does not work!
