12-13-2018, 07:38
Originally posted by bergamesk View Post
Regarding your Chinese Burning Tool. It may be it can not find its config file. Try to run it from C:\*** .
*** - the directory where you unpack the Tool....
Hi,my Tool now on Desktop and when I opened this file that there is one Application program than click it and opened Chinese Tool
I do not understand C/.......
So I do not it to change language
Therefore do you have any recommandation for the SD Card type/Size/Brand etc.,?
I have some SD Cards too
But I need Card Reader too(my Desktop PC does not any slot for the SD Card)
MagicSee do not told me any "DRIVERS"
they just gave me only "Android Tool v2.51"(Chinese)??
And gave me SD Card flashing Tools "Rockchip Create Upgrade Disk Tool v1.53(English)
Hi!
I used low-end Apacer SD card class 4 8Gb https://www.****.co.uk/p/Apacer-Ap8g...ptor/766473802
You can try any other micro SD 4 8 or 16Gb. The 32Gb did not work for me for a some reason.
You can try any card reader from $1 https://www.****.co.uk/itm/0164-989E...IAAOSwuNNb7ApJ the **** is e-b-a-y
The Create upgrade disk tool. https://drive.google.com/file/d/1gi3...A6czQ_fGy/view
The Tool on my computer (Windows 7) did not work from desktop. I moved it with its folder from /Desktop/Create Upgrade.... to C:/Create Upgrade....
