MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    If you can ask the manufacturer to send you a new firmware made using
    './mkimage.sh ota' so the ramdisk is inside the boot image,
    then I can build a root/unroot firmware perhaps for this device using Magisk which is tons better than SuperSU root.
    Already did it for RK3328 and it worked great.
    I see the top part of the box looks like it can hold a coffee cup and since the device will probably get hot too, it might keep your coffee warm too?(only a joke)
    Hi
    yep I already relay your request to MagicSEE
    than we will see whats happen
    note;they responded all my messages/requests very fast!
    So need time and be patient as well than w'll see whats happened
    and before Coffee we have to take some BEERS,cheers
      Hi ,
      wish you could do that with latest X99 , or make AP6255 Drivers work on this one ,
      think it shall run on X99 , or not ???
      greetings / gefattern
      • mo123
        mo123 commented
        Editing a comment
        If Magicsee cooperates, it can help for X99 root too.
      #48
      I hope it works
      such a getting better work X99 in near future
        Hi ,
        that would be fantastic , does Magisk work stock
        with RK Boxes / Bootloader ???
          Hi ,
          Yes, just need a boot image with ramdisk(kernel) inside.
          Then you can have root and root is hidden from all apps you select eg. streaming apps to make them work and file managers can use root etc.
          You device can then be Google Certified and can then run more apps eg. banking apps or new games that don't work on rooted devices etc.
          So manufacturers just need to build a firmware slightly different with the command I posted previously and then I need to repack the firmware to make it work.
            Hi Mo123 ,
            sounds great so it shall work with latest X99 Rom too ??? , i am really interested to play "Critical Ops" on a rooted
            X99 Rom , but "Critical Ops" , does not work with "root" , nice Shooter , good to play with mapped Gamepad , i really
            hate that i am self not able to do this things , till i was young i had a chance to learn all this , but i decided to do other
            things , greetings / gefattern
            • mo123
              mo123 commented
              Editing a comment
              See the next post.
              Seems Rockchip already added some gamepad mapping to new RK3399 firmware.
            #52
            Originally posted by bergamesk View Post
            and I wonder that how about "10-bit" support???
            because X99 does not give you 10-bit!
            For 10-bit they just have a add a simple patch, all my RK3229, RK3328 firmwares already have 10-bit support for h264/h265, so it's not difficult to do.
            You can try to ask Magicsee to see if they can update to the new Rockchip RK3399 SDK optimized for gaming.
            We have optimized RK3399 BOX SDK performance, now it can support 50+fps@720p on PUBG.
            Also we added the feature of keyboard and mouse mapping to Android framework to support personal customization.
            Here is a RK3399 device already using the new software.
              My box shipped today by Gearbest+
              • mo123
                mo123 commented
                Editing a comment
                Would be nice to hear how it works in a few days.
                I though you already have the device.
              #54
              Probably within 10 days I'll collect my new Toy of N6 Max
              I already still use it X99 too where bought from GBest since May/2018
                Originally posted by BidonX99 View Post
                3. (bonus) For smooth video, you need to use special edited versions MXPlayer
                Ultra Mode Lite Version ?
                  de-judder SE version MXPlayer (works smoothly without auto frame rate switching; video 23.9 Hz >> display 50 Hz): [1] & [2]
                  tested on YUNDOO Y8 OS Android 6
                  Yundoo Y8 A6 [RK3399]
                    Hey guys today I got eMail from MagicSEE as they sent me for flashing tool of USB Burning>> "ANDROID TOOL 2.51" but this
                    Tool Chinese!!! how to change it English??
                    When I check Language file in the folder;seems Chinese&English but how does it work?
                    I'v already check it Google search but cant found any release 2.51!!
                    I'v another Tool for using X99 flashing(RK3399) as "Factory Tool 1.51" for example is it competible for N6 ??
                      Use new Factorytool v1.63 and choose Restore at the top if it's full firmware.
                      If it's a small size ota firmware, choose Upgrade at the top.
                      Link here
                      For AndroidTool:
                      Change config.ini
                      [Language]
                      Kinds=2
                      Selected=1
                      LangPath=Language\
                      to
                      Kinds=2
                      Selected=2
                      LangPath=Language\
                        anyone could please check HEVC 10-bit playback using FTMC (remember to install it as system app in order to work) and MX Player Pro in all modes SW, HW and in HW+ (10-bits needs to be checked in codec settings)
                        FTMC -> http://freaktab.org/c488e068fce59f0f
                        MX Player Pro v1.10.26 [Patched/AC3/DTS Mod Lite] -> http://speed4up.com/t6yvaku975dr
                          Link here
                          For AndroidTool:
                          Change config.ini
                          [Language]
                          Kinds=2
                          Selected=1
                          LangPath=Language\
                          to
                          Kinds=2
                          Selected=2
                          LangPath=Language\
                          Thanks+
                          therefore I'v found English version AndroidTool v2.51
                          MagicSee said that do not use other Tool!! use this v2.51
                          Note;tried yr config.setting but its still Chinese!
                          such as all main-menu figures Chinese
                          any trick?
                          But anyway when my Box arrived than I'll try to your first Tool
