MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    trebor Why would we be wrong to Expect GB to get out in front of these (their) fairly obvious issues with Their supply chain... and offer effective solutions proactively?
    At 110$, and undoubtedly 130$ soon... One should reasonably expect the advertised and relatively stable performance. Shield or not.
    You don't recall any bugs, as described here?
    My sample size is a bit small, but two of three are...? for anger management training ?!
    -- bad deal.
    Last edited by ClarkKent; 27 December 2018, 23:08. Reason: typo.. Believe it or not. ;-)
      I have not reviewed this item as such, made mention it existed and currently cheap i think as I normally do, you know as much as me.
      I don't absorb a lot to what other people say, no point getting all uptight an over the top over something I have not experienced.
      Seeing is believing (in my hands on my TV)
      Sure I read what people have to say, make a note on a small piece of paper and move along.
      A cheap enough of a 3399 box came along
      You wanted cheap you had coupon to waste a few bad apples and the sky is falling.
      Buy a Shield if you want, but its locked down so to speak and maybe limited for what you want to do.
      Yes there is workarounds like there maybe workarounds for this box
      GB like all sellers in the land of the Great Wall are sellers they sell,
      You buy, if its faulty they try to fix or refund that all they can do.
      Yes there are loops you need to go thru Pictures Videos etc etc, they pass that info to Maker to see if there is a fix possible
      As they are not the local Y'all-Mart problems dealing with issues is always going to be about.
      Previous Magicsee products have been OK.
      There is a contact at magicsee, ask them avoid the middle man.
      But as you don't have the unit yet, what can they do for you NOW ?
      Magicsee also are sellers and may need to get intouch with the software Dev to resolve problems,
      If he is in AU he will be on holidays for a few weeks to come Sun Beach and Booze and would mention Babes but that is being UPC or something
      If it worries you so much Cancel your order.
      Happy Holidays Y'all
        trebor I feel ya. Fair points, well taken.
        Apprehension is raised I think cause I can barely get around an amlogic... Fumbling back from the "edge" a couple of lucky times.
        Not so confident about a rock, but lust for horsepower got me.
        I must have mixed up your reviews, but I thought ran an antutu, etc. My bad.
        Correctly though, the issues are too far away for much concern... perhaps none?
        ​​​​​​... 'Like to think so, it's 2019 & s/b an ez obstacle.
        btw, I'm not a 35$ disposable box guy, nor a 200$ "restricted" device man. Had My budget allowed, probably gone with rkm39. Maybe next Santa.
          trebor yep, my bad! I should have double checked for your review if I was "checking all the boxes" ​​​​​​
          So I am requesting that GB get your own n6 for a look-see. Maybe they'd get you a sunvell A95X Max 4/64 H6 too. Perhaps a good performer for the middle budget minded.
          But your running review on the Magicsee would be great for considering. Thnx!
          now.
            Ran the Antutu benchmark got 80023. Which is less than stellar. I suppose if magicsee were to optimize the Firmware it will get a higher score. I saw this box get a score of 100000 but i was sale mislead.Click image for larger version  Name:	20181228_073219.jpg Views:	1 Size:	71.4 KB ID:	756360
ID:	756362 the idle temperatures are good. Saw the device got maximum of 65-68 while playing YouTube and Netflix.
                The CPU throttles down when idle. Apologies to everyone it is not a bug. It must have been running something in the background when i tested it. Hope this helps. Click image for larger version
                  What version antutu?
                  I have seen elsewhere that the heatsink has been misaligned just a bit, corrected temp dropped about 15f. Any lower temp should return a little higher score.
                  Looks to me like taller skid pads for more bottom clearance might help the "chimney " cooling effect.
                    Hi ,
                    yes cooling helps , from about 80000 to 105000 , with cooling & debloating system , Box X99 ,
                    greetings / gefattern
                      [QUOTE=gefattern;n756369]Hi ,
                      sidglide
                      ...is the round lid (@ exhaust port) aluminum, or sadly plastic?
                        [QUOTE=ClarkKent;n756370]
                        Hi ,
                        sidglide
ID:	756378 The lid is sadly plastic Mate, however it is vented from all sides. So we place a USB fan in exhaust mode (blowing air away) from the box it should be sufficient cooled. I have a old set of laptop fans will install and check if it changes the scores.
                          Hi ,
                          sidglide
                          But the device has a certain amount of heft to it.. i suppose the heatsink should be beefy.
                            I used the latest version of Antutu with the addon from play store.
                              Hi ,
                              Hi gefattern,
                              Will install the fan and test again
                              Cheers
                                Click image for larger version  Name:	20181228_095633.jpg Views:	1 Size:	88.0 KB ID:	756385 get set and go...
