MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    Originally posted by bergamesk View Post
    Hi dear Gefattern
    Today I'v got a message fm MagicSee as yesterday I
    But I wonder that how we can make flashing via "PC" need to ask them!
    In fact I do not know USB Burning Tool flash proceed??
    Bye++v
    Thanks for info. Just found the latest tutorial how to upgrade N6 https://youtu.be/hQBZAj5tzdI
      Root check
        Hi ,
        for sure the same way as all RK Boxes , but i want to know , is SuperSU
        update possible both App & Binaries , thanks ,
        greetings / gefattern
          How to check that? I did not know
            Hi ,
            It won't be possible.
            My firmwares are the only ones that can use the latest SuperSU and it's very complicated changes no Chinese manufacturer could do on their own.
              Hi ,
              thought the App self ask for it , no update in Playstore , does the App not
              ask for Binaries update ??? , thanks ,
                Hi ,
                but your Roms are not for RK3399 , until now you are busy with RK3228 , or not ???
                and why it works in past with older RK Boards like RK3288 / RK3368 , strange that
                the chinese Rom Devs are not interested to make it work ,
                ​​​​​​​greetings / gefattern
                  Hi ,
                  check test video; 2.76:SUPERSU
                    check min. 6:06(above test video)
                    Install it this Apk. fm PlayStore>>> https://play.google.com/store/apps/d...tchecker&hl=en
                    (as same above Apk. for the Tester used it)
                      Hey guys
                      This Manufacturer work very fast
                      Yesterday I sent a msg to them and asking some of things including "How to Flashing...."
                      So they responded and given YTube video for that! (Dec3) Thanks+
                        just wondering is there a way to flashing by USB Burning Tool???
                        SD Card processing a little bit come to confuse me!
                          cancelled+
                          wrong sent msg+
                            A123
                            Did you already flashed your Box ??
                              If you can ask the manufacturer to send you a new firmware made using
                              './mkimage.sh ota' so the ramdisk is inside the boot image,
                              then I can build a root/unroot firmware perhaps for this device using Magisk which is tons better than SuperSU root.
                              Already did it for RK3328 and it worked great.
                              I see the top part of the box looks like it can hold a coffee cup and since the device will probably get hot too, it might keep your coffee warm too?(only a joke)
                                Hi
                                Today got another eMail from MagicSEE that they will show up How to flash by USB Burning tool
                                watch this>>>> https://www.youtube.com/watch?v=KIFZdOZfstI&t=5s
                                Manufacturer works well such as when you asked something than they will respond very soon!
