MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    Originally posted by sidglide View Post
    Hi Guys,
    I got my Box yesterday. I have been trying putting the box thought it paces.
    Found quite a lot of issue.
    1. Netflix the oldest version 4.XX.XX work, you try to go to version 6 and you will get an incompatibility error
    2. Amazon Prime Video crashes the moment you try to play a video
    3. Screen saver doesn't work at all i set the screensaver time as 5 minutes and turn off after 30 minutes of no activity both of the functions do not work.
    4. I observed some HDMI sync issues as well where the image will flicker intermittently.
    Hope they and fix the issues with the firmware.
    Cheers,
    Sid
    1-2;I do not use NetFlix and Amazon Prime,but you right cause of Box has lot of issues!
    3-ScreenSaver;doesnt work properly!(but manualy work)
    4-Lip-Sync issue;same as mine!
    Note;picture quality(you meant from where? such as MediaCenter or any other Player?)
    PQ;X99 a little bit better!
    So,everyone who has N6 should be contacted via directly(eMail) MagicSee Co.
    [email protected]
      Lets see how this develops bro; hoping against hope that they will improve the firmware support.
      What i think it is poorly optimized if they give it time and effort it might turn out to be a great box.
      Havent tried the USB 3.1 yet but hopefully it will improve.
      Like my old X96 kept getting updated for about 2 years and now it is stable and good.
      Keep in mind;"Type-C 3.1 Port" does not work!!
      Note;I'v tried with my Type-C Adapter and not worked(they know this issue!)
      They sent me msg before yesterday;they will release firmware for this issue!
      O.K but but about others
        A Tricky
        Last night I worked again! and found this solution for my 1080p(10Mbit and over video files)
        Player;MX Pro(v.1.10.27)
        Video Files;1080p 10Mbit and over
        Format;MP4/WMV/MKV/AVI
        There is Decoder section on MXPro Player,selecting HW+,HW and SW
        What I did;unticked all HW+ and HW Decoding functions!! and ticked SW only
        Than all my files played smooth&well!!
        Seems that you can play with only SW decoding for this very high bit-rate videos,if you select HW+ or HW then freeze/not play!
        I never any experienced with my all other Boxes(AML912 or RK3399)!! when I use MX Player
        even my last box X99 and I always select and well played with HW+ !!
        And yesterday I wrote my KODI(17 or 18) experience with my high bit-rate video files
        Where if you select MediaCodecs from Kodi Video Setting than all videos freeze!
        So you should not be selected Codecs!
          Originally posted by bergamesk View Post
          A Tricky
          Thanks for sharing bro!!
          I will compile a list of all the bugs ans send it across to the magicsee address [email protected]
          Hopefully over a period time they can squah all of them
          Another thing that i found strane was the lack of OTA update application.
          My 3 year old TV box had it. I will add the same to that mail as well.
            Hi sidglide
            I'v removed lot of Apps!
            such as NetFlix,Skype,Twitter,Mobdro,ShowBox,etc.,
            USB ports always powered/running!
            But my Box very cool,no any Heat issue(room temp around 18/19C)
            Note;when I check thru KODI>>System Info;Hardware and have seen 2C !!! is it possible?? always 2C!!
            when IDLE
            Total Memory;3846MB
            Free Memory;3048MB
            I used another app from the play store; CPUZ was not reporting temperatures correctly, it was showing 26C all the time.
            I used CPU Monitor to check temprature. It reported a maximum of 81c and minimum of 65c.
              This Device "BUG Champ"
                Originally posted by trebor View Post
                My suggestion is to just advise Magicsee of the problems, with video and pictures,
                Were pretty good with there support/fixes of the amlogic software.
                Keep at them, for a solution to the woe's
                Happy Holidays
                So?... Just "shotgun" whatever lucky magicsee rep happens to receive the email??
                Surely we, or they, or GB could come up with with a more coordinating process that compresses issues into a format that insurers the most complete corrections? The best Effective Results, with the least Fustration for all.
                Seems GB should step up to their supplier, and lead the process of relaying to magicsee.. the immediate fw needs, so they (Builder and Seller) can get a comprehensive fix to disappointed buyers asap..
                27? is a fallacy
                86? is box deadly.
                No idle for cpu is hard to believe, and unseen by me before.. If accurate, bad... and unacceptable.
                  Hi ,
                  maybe AIDA64 App ??? , the USB Power Bug exist on X99 too , so you can see , the main Code
                  of FW is the same , 2C is for sure a Bug , but does this Box support temperatures check ,
                  greetings / gefattern
                    My CPU cold&freeze at "2 Celcius" BRAVO
                    Because I'm use it this Box in Siberia/Russia under -45C
                    cheers
                      On-OFF BUG!!
                      Well,everyday I'v found another BUG
                      But this On-Off Bug really bother me WTF
                      In fact I'v already told you this Bug before yesterday
                      >From Remote commander "Power OFF"(long press red button) if you turn Off than device never opened if the duration such as
                      more than 30min.!!!
                      And now found another version On-Off Bug;even if you turn to Stand-By mode than device never turn on again if the duration such as
                      more than 1 hour
                      So if your Off or Stand-by duration more than 1 hour(even less!!) this device never turn ON
                      And "No Comment"
                      Like a Joke
                      Well I like this GAME
                        And you guys,pls stay away at present from this Box!
                        Be patient and wait if you think to buy N6 MAX
                        If they will release proper firmware than we will see whats happen,otherwise dont buy N6 MAX
                        or at least think to buy X99
                          I need your advise
                          Re;Air-Mouse(or Fly-Mouse like our X99 remote)
                          To use all type Boxes,because those old type remotes make me crazy also N6 Remote is not good(especially
                          very narrow direction use!) I need definitelly to buy Fly-Mouse
                          Pls help me for this remote(price around $ 10-30)
                            Hi ,
                            that was no good Idea , hope you get a good working one , think it is best to buy a Shield ,
                            hope it can be fixed with the new Rom ,
                            good luck / gefattern
                            I agree with you, I bought the Nvidia Shield and really like it, works great like everyone says....
                            Amazon has been selling them for $149.00...
                              A Tricky
                              v1.10.27 is an old version uninstall it and install this one MX Player Pro v1.10.31 [Patched/AC3/DTS Mod Lite] -> http://freaktab.org/bc7f579f6ed7ac68
                                I need your advise
                                Hi ,
                                why u not use a stock BT Mouse with Keyboard , i use the Logitech K330 , works great with Mouse
                                on every TVBox ,
                                • trebor
                                  trebor commented
                                  Editing a comment
                                  Agree with that 100% remotes are just so REMOTE
                                  Unless its a Z9S remote, the too die for type
